Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Unread 22-02-2010, 15:24
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Camera Code in main thread + watchdog = twitching servo?
Ok here is a problem that we are finding when we combined the default circle tracker code, with some modifications to remove the pan/tilt servos.
When we add this code into our moderately sized project, we find that our first servo that we instantiate twitches. This happens regardless of where which pwm port we plug it into.
My thoughts were that since the watchdog is running in the background and there are a few Thread.yield() calls in the canned code we got. We are confusing the watchdog making it start it's shtf shutdown sequence, starting with the first servo it can find, the one w/ the lowest address. Then after the thread stops yielding, it recovers and sets the servo to the specific value that it was before the thread yielded.
Is this a reasonable explanation or is this not possible with the way the watchdog works. Is this what happens when you yield the main robot thread?
Unread 22-02-2010, 16:26
Bart Bart is offline
FRC #2625
Bart is an unknown quantity at this point
Re: Camera Code in main thread + watchdog = twitching servo?
Team 2625 here, we have the exact problem here, I think its probably because the camera takes too much time to process and the watchdog dies before it's fed.
Camera servo mcristina444 NI LabVIEW 12 14-02-2010 23:12
Camera servo trouble Demothesis Electrical 5 27-01-2007 17:15
CMU Camera same as last year? 2005 == 2006? Chris_Elston Programming 3 12-02-2006 18:33
Same bore, same stroke, same mounting--is it legal? Billfred Pneumatics 2 20-02-2005 00:41
Camera Servo Obi Programming 2 30-01-2005 17:09
