Go to Post Chief Delphi's Greatest Hits vol. 47: Overreactions to Q&A responses - Lil' Lavery [more]
Unread 24-02-2010, 21:14
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
714's Winch Test
http://www.youtube.com/watch?v=SqlaiC7fHv0
Unread 24-02-2010, 21:28
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: 714's Winch Test
it looks like you guys might get caught under the tunnel, unless im missing something.
Unread 26-02-2010, 18:01
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
is it sliding down once you get up to the top? do you have a pawl or anything to hold it in place? Once the power is off, you don't want it to fall below the platform level or you get 0 points.
Unread 26-02-2010, 18:06
Yes, do you have any method to prevent it from backdriving once power is shut off?
Unread 26-02-2010, 18:33
5n1p3r's Avatar
IM 5n1p3r
AKA: Matthew
Well we have the solenoid for the .5" air tank set to normally open so only when the arm+winch are being moved does the braking system disengage... when off it'll be braking. In order to slide down the motors would have to spin backwards w/o power and our braking system must fail... very unlikely although possible but 7 lbs of pressure being applied to that brake and the motors resistance will do well over hold our robot in position.
Test, Edit, Build, Deploy, Test Ether NI LabVIEW 1 23-02-2010 20:32
small scale winch Pneumaticsman Motors 11 03-02-2010 12:28
Winch System SHS Blue Devils General Forum 2 12-01-2008 18:50
Winch Nitroxextreme Motors 10 04-02-2005 00:42
Winch edomus General Forum 43 21-02-2004 02:30
