Go to Post bedtime? there's no bedtime while chief delphi is up and running! - Alex Cormier [more]
Unread 26-02-2010, 19:18
lollypop2020 lollypop2020 is offline
FRC #2733 (Pigmice)
lollypop2020 is an unknown quantity at this point
Broken Beam Sensor?
Our team needs a way of seeing if we have a ball in position to be kicked or not and a broken beam sensor or something similar seems like it would be perfect. Could someone recommend one that is compatible with the control system and is legal for FRC?
Unread 26-02-2010, 19:27
kavisiegel kavisiegel is offline
FRC #0061 (The Shifters)
kavisiegel is an unknown quantity at this point
Re: Broken Beam Sensor?
We used a garage door sensor with a bit of custom electronics to give us a digital signal. The mentors said they couldn't find any rules against it.
www.team61.com
Unread 26-02-2010, 19:28
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
we too are using a garage door sensor
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 26-02-2010, 21:30
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We are using a IR broken-beam sensor, no idea where we got it from (Jim says he's had it for a while), seems to work great, thats all I can say on that.
As for the rules, there are some rule regarding sensors. Not many. They are categorized as custom circuits, so <R03> says what custom circuits can and cannot do (you can't directly drive a motor or use any wireless communication), <R45> says where they can get power from (20 amp breaker on PD board or 5v supply on DSC or Analog board), <R64> lets you put them on a CAN bus, <R68> tells you where you can connect their outputs (More custom circuits, DSC, Analog board, Serial port, Ethernet 2 port, CAN bus). The only other rules regarding sensors are the size and weight limits. Basically, if you can find a sensor that runs on 12 of 5 volts and outputs a digital signal (TTL or open collector)
Kettering Motorsports
Unread 26-02-2010, 22:17
AKA: Dr. Brooks
no team (WRRF)
We use the Banner QS18VN6LV sensor.
It is a red light sensor, so you can see the beam.
You put a patch of retro-reflective tape on
the other side where the beam hits.
Brown wire goes to 12 volts,
blue wire goes to ground of the digital input
black (or white) wire goes to signal.
The sensor costs around $60 last I checked.
Eugene
Unread 26-02-2010, 22:26
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
You can use just about any input sensor you wish. It is outputs that the rules are much more concerned with.
Unread 26-02-2010, 22:37
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
The BANNER Sensors mentioned above are great sensors.
For this application you may also want to consider a current sensor on the roller/vacuum motor, then you dont have to worry about placing a beam sensor or reflective tape or anything like that. (if you have no active possession mechanism ignore this comment)
Unread 26-02-2010, 23:26
apalrd's Avatar
More Torque!
VRC #3333
Depending on the application, an encoder could work as well. It would detect a drop in speed that comes with acquiring a ball. The beam sensor seems like the best solution. It is simple, requiring only either an integrated sensor and reflective tape or a separate emiter/reciever, and feeds the output straight into a DIO pin. Plain and simple: a boolean value that tells you flat out DO I HAVE A BALL OR NOT? even if the ball is only sorta on your collection mechanism or the roller isn't running.
As for setting up the sensor, I recommend you power up the robot and look at the sensor output while mounting it. This can tell you if you have everything lined up and the software can see it.
Unread 27-02-2010, 02:22
FRC #2733 (Pigmice)
A Banner QS18VN6LV looks absolutely perfect. However, do we have to be concerned about:
<R02> ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically PROHIBITED from use on the ROBOT include (but are not limited to):
A. Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any DRIVERS and/or COACHES and/or interfere with their ability to safely control their ROBOT
B. Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction or hindrance affecting the outcome of a MATCH
C. Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another robot,including vision systems, acoustic range finders, sonars, infra-red proximity detectors, etc.(e.g. including imagery on your robot that, to a reasonably astute observer, mimics the VISION TARGET)
D. Exposed lasers of any type (COTS devices with completely enclosed integral lasers, such as a laser ring gyro, are permitted)
E. Flammable gasses
F. Any devices intended to produce flames or pyrotechnics
G. Materials that off-gas noxious or toxic gasses
H. Materials that produce hazardous inhalable particles
I. Caustic chemicals
J. Hydraulic fluids or hydraulic components
Unread 27-02-2010, 08:17
The WorldBeam QS18 series uses conventional LEDs, not lasers.
Unread 27-02-2010, 09:16
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Incorrect according to this, although the exact model above does use LEDs.
Please be careful when making assumptions about parts.
___________________
- Tennyson, Ulysses
pic: Beam Bending Example kramarczyk Technical Discussion 22 19-05-2008 08:08
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
Link to sensor manual broken on FIRST site! keen101 Electrical 2 06-01-2008 15:23
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
