Go to Post I think I need a bigger cup of coffee.... - JaneYoung [more]
Unread 27-02-2010, 17:19
NinjaWithBurnin NinjaWithBurnin is offline
Professional FBI-C
AKA: The Ender
FRC #1749 (Renesiance)
Rookie Year: 2015
NinjaWithBurnin is an unknown quantity at this point
Camera in Labview
I've been having some problems with our camera
just like many other teams the camera will work when hooked into the computer. but will not work with the cRIO. when we run the dashboard the camera window is white and says 'Timeout in Camera Communications'
does anyone know how to solve this in labview?
thanks
Registered Assassin & Bodyguard
Unread 27-02-2010, 18:23
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Camera in Labview
couple questions:
1. did you run the Axis Camera setup wizard, and is there an account on the camera with a username and password of frc and frc?
2. Is there code running on the crio? It dosent need to use the camera, it just has to run.
3. Is the IP 192.168.0.90?
4. Does the rest of the robot comm work fine?
5. did you use a crossover cable to eth2 on the cRio?
Kettering Motorsports
Unread 27-02-2010, 18:34
Try all those suggestions by Palardy.
Assuming all the latest updates have been applied. The second most common reason for this has been the state the camera was left in after last year's experiments.
The safest thing to do is to reset the camera altogether, then use the "Setup Axis Camera" tool.
Reset by pulling the power, then holding the reset button while plugging the power back in and continuing to hold until you get the orange light around the lens.
Unread 27-02-2010, 22:23
Just for completeness -- have you applied the Mandatory Driver Station Update that was released February 15? The "Timeout" message can happen if you're running the original Dashboard application that was on the Classmate when it was shipped.
Unread 01-03-2010, 20:45
Wiz Wiz is offline
Wiz is infamous around these partsWiz is infamous around these parts
Thanks for helping Ninja out; don't hesitate to point him in the direction of the proper documentation too.
Unread 11-03-2010, 13:45
dilweed68 dilweed68 is offline
FRC #1789
dilweed68 is an unknown quantity at this point
hi my name is rj and im from teams 1789 the cliffhangers, im having a similar problem. when i attempt to go to the cameras site it won,t even let me connect any ideas as to why
Labview camera problem solutions glitch NI LabVIEW 0 24-01-2010 15:19
Programing camera in labview frcchile NI LabVIEW 1 23-01-2009 13:03
Axis Camera w/ Labview problem lamoreaux2198 Technical Discussion 2 14-01-2009 04:38
Axis Camera Programming in Labview Striker_27 NI LabVIEW 10 09-01-2009 19:19
Camera and Labview phrontist LabView and Data Acquisition 1 28-01-2006 21:07
