Go to Post Remember: This is High School Competition. - rich2202 [more]
Unread 28-02-2010, 21:29
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
USB power?
So, I got a used ipod and it doesn't work unless its plugged into a pc. When its unplugged, it refuses to turn on. Might be a battery issue or something... So I was thinking to maybe buy another USB connector thing for the ipod and cut it in half, and powering it like that through an external battery or something. So does anyone know how much power the usb gives, and if this is at all possible?
(btw, I hate iPods, get a zune! Im just using this little thing until I get my zune HD )
EDIT:
wow two iPod failing topics in a single forum! That has to say something
Unread 28-02-2010, 22:05
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: USB power?
like this?
http://images.google.com/images?hl=e...harger&spell=1
USB is generally 5 vDC and half an amp.
Unread 28-02-2010, 22:29
Billfred's Avatar
Billfred Billfred is offline
Re: USB power?
Have you consulted a site like iFixit to see about replacing your battery? I replaced a headphone jack on my 5th-gen iPod with very little trouble; all you have to do is have a steady hand and the right tools (which most iPod repair sites include in their kit or sell for cheap as well).
Unread 01-03-2010, 18:27
AKA: Brandon Liatys
Re: USB power?
Wow I like the Altoids container thing, I have a ton of them laying around, Ill try that
Thanks guys
EDIT:
After more shopping around, I found http://www.unplggd.com/unplggd/diy-p...charger-100359
Gonna try that out tomorrow.
Unread 01-03-2010, 18:47
Chris is me's Avatar
AKA: Pinecone
Re: USB power?
With appropriate tools and a spare iPod or USB cable to cut up, you can make something that can power any USB device out of a 9v battery. You need something to limit the voltage to 5 volts (I forget what it's called, but it's at Radio Shack), but it's really handy to have in your pocket when you need to power a Nintendo DS (not a USB device but can charge off USB current), iPhone, iPod, or camera for an hour or so.
I bought my dad all the parts he'd need to make his own, wrapped them in a box, and gave it to him for his birthday. I hope he figures out how to put it together by May.
As for your iPod, I would recommend you get the battery changed in it. You can do it yourself for $40. If it's in warranty you can send it to Apple for free.
Unread 01-03-2010, 19:24
AKA: Brandon Liatys
Re: USB power?
Im having a hard time tracking down a female usb port. On ebay theres like bundles of 20 for like 15$. I only will buy one, from a US seller.
I looked at radio shack also, they didn't have any...(at least on the website)
Unread 01-03-2010, 19:28
AKA: Pinecone
Re: USB power?
Look for usb extension cables of any sort, then just cut off the cable part and use the power wires for your project.
Unread 01-03-2010, 20:03
AKA: Brandon Liatys
Re: USB power?
http://cgi.ebay.com/NEW-USB-2-0-A-MA...item5190b2459f
Just checken if that would be ok. Looks to me like the wires arnt colored (or Im just paranoid about screwing this up...)
Unread 04-03-2010, 09:45
Re: USB power?
Brandon,
The batteries in iPods die after a while and are fairly easy to replace. There are many sources on the Internet and you can also find detailed instructions on how to open the case without damaging anything. Most places that sell the battery also include case openers at no charge. The battery comes with a flex circuit board already attached, there is no soldering. Simply open the case, remove the battery and release the flex. Reverse operation with the new battery and close it up. Then charge of course, the battery is not shipped charged.
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
USB Chicklet Power Smoking_Gun Control System 5 25-02-2007 02:06
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
USB I/O CJO Control System 2 15-10-2005 20:17
