Go to Post you are never an alumni of FIRST, you can always be there, mentoring, learning, creating. - KelliV [more]
Unread 01-03-2010, 19:54
Philipose Philipose is offline
FRC #0772
Philipose is an unknown quantity at this point
Using driver station on another pc
does anyone know how i can make the driver station run on another computer, the same one that is in the driver account? thanks in advance
Unread 01-03-2010, 19:56
FRC #0772
Re: Using driver station on another pc
nvm i found the answer, that was a pretty dumb question
Unread 04-03-2010, 01:16
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
We might need to do this tomorrow. I assume it is just copying the .exe file for the driverstation and running a dashboard project on the other computer, correct?
If not let me know, we'll be in a bit of trouble!
Unread 04-03-2010, 01:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Just to be clear, you must be using the Classmate PC as the Driver's Station during the competition.
Having said that, running the Driver's Station Update on a PC other than the Classmate will allow you to install the Driver's Station on that computer.
Red Robot Code Light in the Driver Station (Using C/C++) robotic321 FRC Control System 3 28-01-2010 16:03
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
paper: Set and display your Auto-Mode using LabVIEW and the Driver Station PhilBot Extra Discussion 0 11-02-2009 12:32
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Using driver station digital inputs Japper FRC Control System 6 19-01-2009 20:01
