Go to Post Yes, this year's championships could be decided by cheesecake. - MrJohnston [more]
Unread 01-03-2010, 20:05
nick_champ_2 nick_champ_2 is offline
AKA: Nick Reed
FRC #2902 (Nyack)
nick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the rough
Send a message via Yahoo to nick_champ_2
Pneumatic compressor not starting
We need help programming the compressor to start in auto and teleop.
attached is a copy of the code.
Unread 01-03-2010, 21:05
Re: Pneumatic compressor not starting
Sorry, I can't see your code attachment where I am.
The compressor only needs to be in Begin.vi, then it's actually active in the background everywhere else.
http://www.chiefdelphi.com/forums/at...8&d=1264605003
Here's the full set: http://www.chiefdelphi.com/forums/sh...9&postcount=15
Unread 01-03-2010, 21:43
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Move the start.vi so it follows the setref.vi
That's the only place you will need it for both Autonomous and Teleop.
Unread 01-03-2010, 22:25
The compressor part of Begin.vi looks fine. There's no need for you to do anything special in Autonomous or Teleop; the compressor control is handled automatically by a separate task that the Compressor Start sets up for you. You can close the compressor in Finish.vi if you're a stickler for making things "just so", but it really won't make a difference if you leave that step out.
Unread 01-03-2010, 22:38
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
did you check to see if you wired the correct paths for the specified components?
Also try a basic relay program to see if your relay is working (WARNING: be careful though, the comp will not off, so if it works, disable it right away). Then you know it's the IO.
Have you electrical members check the wiring.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Compressor not stopping at 120psi drtysteve384 Pneumatics 10 25-02-2010 10:11
Compressor not working. Alexandstein Pneumatics 15 10-02-2010 08:57
Compressor NOT Working (multiple trials already) Noel Pneumatics 10 02-02-2009 18:38
Pneumatic Compressor Jake Lewis Inventor 1 12-02-2005 16:51
Not using your pneumatic order?? jjv General Forum 0 18-02-2004 08:36
