Charging pneumatics system before match
After we precharge the pneumatics system at the pit, do we have to wait until the autonomous mode before we can charge the pneumatics system? I searched on CD but most of the posts are about off-board compressor in terms of pre-charging.
The only other way I know how to charge the system is to tether to the cRIO and enable the robot while it is on the robot cart. Is there an easier way? |
Re: Charging pneumatics system before match
Ed,
There currently is no ruling on when or if a team can pre-charge their pneumatic system prior to entering the field other than for off board compressors. In my opinion, safety demands that no robot be pre-charged in the pit and left in an energized state while waiting in the queue. Teams that use off board compressors should be given time to charge while on the field during setup but again there is no rule on that. In the past, the event managers decided when, how and if teams could pre-charge their pneumatics. For all off board compressor users, please be advised that the KOP compressor or equivalent, must be under Crio control when charging the pneumatic system. |
I forgot to mention that we have an onboard compressor. I probably should not have used the term pre-charge because it made it sound like we have an off-board compressor. I have to charge it somehow before autonomous period start or the kicker is not going to work. When will they allow teams to run the compressor? In disabled state, the compressor does not run. The only way I know is to enable it through tether to cRIO while in queue. Or will they allow teams to do that on the field before autonomous period?
Ed,
I don't have an answer for you yet. I would think the safest is on the field but that would add to the field turn around time. |
How do they do it in past years? This is our second year in FRC and first time using pneumatics so we don't know what to expect.
I think the determination was done on an event by event basis.
#7
At NJ we arrived on the field pre-charged, with a safety lock-out (a metal bar with a long bright pink flag attached to it) that was the last thing pulled off the robot before the team left the robot on the field.
Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. |
#8
Ed,
In 2008 we used pneumatics for our arm and gripper. What we would do is have the controls all set to charge went we got into queue and then with one minute left in the match before ours, charge it up. This way we aren't walking around with a robot that is "locked and loaded", but at the same time we weren't delaying the start of the match by doing it on the field during match setup. Now, there wasn't as much of a risk with stored energy then like a kicker this year, so I would definitely recommend a safety bar/latch of some sort. |
#10
Tetra year was the last year we needed to pre-charge, and we did it in the queue also, when the match in front of us was almost over.
This year we can fill the tank(s) in the pit, our system doesn't fill cylinders until autonomous starts. |
#11
Our team is going to start with pre-charged pneumatics because they keep our kicker locked in a safe position. In fact, all of our pneumatics are designed to store in a safe position with the power off, so our robot is arguably safer with the pneumatics completely pressurized.
| Charging a System | Zultraranger | Pneumatics | 7 | 05-02-2008 21:08 |
| pic: MARS making repairs before the last match | Billfred | Extra Discussion | 3 | 10-09-2007 16:52 |
| Spring pulling before match or while in match?? | Bomberofdoom | Technical Discussion | 3 | 11-01-2007 08:03 |
| pic: 1072 before the match | Billfred | Extra Discussion | 1 | 06-01-2007 22:30 |
| Pump operation before match | Jeff Waegelin | Pneumatics | 19 | 29-04-2003 09:42 |
