In our arm we have 3 solenoids that shoot at the same time to raise our arm and i was wondering if we can connect all 3 solenoids to the same relay on the cRio, I have look on the first web site and i could not find anything that said that it was legal or illegal. Have anyone try it.
Please help! Thank you. |
Re: Solenoids Wire
Solenoids can be connected to either the solenoid module on the cRio, -OR- to a spike relay...
Per <R49-A> you may connect multiple solenoids to a single spike relay. I don't see anything specifically disallowing controlling multiple solenoids from a single connection on the cRio solenoid module, however I don't recommend it. That module was designed to support 8 separate output signals, not multiple solenoids per output hope that helps |
Re: Solenoids Wire
tanguma,
The NI 9472 module can handle 750 ma per output and a max current for the sum of all outputs is 6 amps. |
Re: Solenoids Wire
ok thank you guys for your help
| Solenoids | Rohan_DHS | Rules/Strategy | 2 | 04-02-2006 00:11 |
| How does your team wire your Double Solenoids? | Doug G | Pneumatics | 14 | 17-02-2005 23:25 |
| # of solenoids | Brawler006 | Pneumatics | 5 | 01-02-2004 11:12 |
| Solenoids | archiver | 2001 | 9 | 23-06-2002 23:47 |
| Solenoids | turbidum | Rules/Strategy | 1 | 09-01-2002 21:26 |
