Go to Post It wasn't about the ROBOT, or about whether I was male or female, it was about getting to compete in something that was just SO cool. - BandChick [more]
Unread 05-03-2010, 22:19
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Buying battery wire online?
I am having a hard time finding a source for more battery wire.
We need to rebuild our set of batteries, as general use (and some poor oversight from mentors previously) has resulted in us having fairly shoddy battery connections.
I see that for 15 dollars a pair, AndyMark will sell me complete Anderson pairs. I'm trying to see if that's a good price, but I can only seem to find 6 AWG wire in bajillion-foot spools on Mouser, and Digikey is absolutely horrible to try to search.
Does anyone have a good source for both Anderson power pole connectors and wire to go with them?
Thanks,
Jacob
Aren't signatures a bit outdated?
Unread 05-03-2010, 22:34
Mark Rozitis
Posts: n/a
Re: Buying battery wire online?
Thanks,
Jacob
I can't see in great detail here on the blackberry but maybe this link will help and it looks like you may be able to order online direct from them for some products.
http://store.andersonpower.com/PowerPoles.aspx
m
Unread 05-03-2010, 22:54
AKA: Dr. Brooks
no team (WRRF)
SB50 connector, www.powerwerx.com $4
Two megalugs (50 cents each) from spectro wire and cable $1
www.spectrowireandcable.com
One foot of red #6 welding cable, $1.5 per foot,
and one foot of black #6 welding cable $3
http://www.missouriwindandsolar.com
Your materials will cost $8, but you must add shipping.
What will eat your budget is the crimper,
around $100, unless you settle for the hammer
crimper from http://www.missouriwindandsolar.com
The battery wire furnished in the KOP this year was
very good, the best that FIRST has ever served up,
but welding cable has finer stranding and is a little
more limp as a result.
Unread 05-03-2010, 23:01
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Thanks,
Jacob
This might help. http://www.powerwerx.com/wire-cable/...-zip-cord.html for the wires. Site navigation is good, so you can also find the connectors easily.
Unread 06-03-2010, 08:11
Jacob,
For the few dollars more, the AndyMark cables are the way to go. They are professionally crimped and just the right size.
Unread 06-03-2010, 15:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've had good luck with wire from eBay, and this crimper http://www.harborfreight.com/cpi/cta...emnumber=66150. It has hexgonal dies. We also solder after crimping.
Unread 07-03-2010, 15:22
Why?
While soldering can keep a badly crimped connection from coming apart, it has been my experience that it can also make the connection brittle and prone to actually breaking the wire where it enters the crimp if any significant sideways tension or vibration is present. A properly crimped connection isn't going to fail before the connector or the wire itself does.
Unread 07-03-2010, 19:19
kevinhorn kevinhorn is offline
FRC #3213 (Thunder Tech)
kevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nice
Jacob,
Powerwerx is a good source for both wire and APP products. They offer a crimper for 50 amp APPs is just $15 and does a great job. In a pinch you might be able to use the crimper on the Brundy color code terminals as well.
When ordering the 50 amp shells be sure to keep to the red shells as they are keyed by color and only connect to like colored shells. While the you are making an order you might want to pickup some 50 amp contacts that are made for smaller gauge wire to convert your battery charger to direct plug to the battery.
The #6 AWG in red black pair seems expensive but remember that a 25' roll has 50' of wire and the pairing is handy if you place your battery any distance away from your PD.
buying books online Molten Chit-Chat 9 24-08-2008 12:02
Best 6 Gauge Wire Battery Connector Alex698 Electrical 8 03-10-2006 23:45
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
