Rules, changed by the ref, or correct interpretation?
OK,
I have a question of rules interpretation. In finals match 1 at Peachtree, The alliances finished the match tied at 7 to 7. As the buzzer sounded, a robot jammed into its goal pushing balls, one of which passed through the scoring box and was scored (creating the tie). the 10 second timer counted to zero with no further changes. The refs gathered around the robot, and found several balls jammed in the goal with the robot, none of which passed through the scoring box. After a brief discussion, they added the balls that were jammed in with the robot to the alliance score, giving that alliance the win. My question: based on this definition: Quote:
Re: Rules, changed by the ref, or correct interpretation?
Sounds like an incorrect interpretation to me.
The rules you have posted are pretty clear, the balls had not passed through the counter so they were not scored. |
I have to agree with Kevin. I see no place where the rules could be confused.
*Alex goes to download the latest manual to bring to competition. |
Most definitely a bad call. Down at BAE there were a few last ditch efforts like this, but none of the balls were counted if they didn't pass through the counter. We had a pretty bad call though on a hang one match, as the ref used a piece of paper to check if our mechanism was above or below the plane. They ruled against it, but I felt like an official measurement should have been taken from the ground to see if it was most definitely below.
At NJ Regional 2753's eight wheel base got stuck on the bump and could not move - even with all eight wheels on the playing surface (4 on the carpet and 4 on the bump). This put our robot at the 45 degree angle of the bump. We got wedged in a very unusual position. Our hanging arm stayed perfectly straight up relative to the robot base; however, the refs said our hanging mechanism extended beyond beyond our perimeter since the robot was "tipped". Our students unsuccessfully challenged the penalty. The ref's reasoning was something like the following: Since robot could not move for over 10 seconds, the judgement was that our robot was "tipped". Later in the day, the head ref did conclude that the call was wrong (however it was too late to change the scoring).
Unfortunately, the rules do not define tipping. Certainly when all of your wheels are on the playing surface, it can not be tipped. A definition of a Tipped Robot needs to be included as an update. |
#7
Tom,
The only place that the word "tipped" appears in this year's Game section of the manual is G37 about when it is legal to contact someone outside the bumper zone. For this rule the definition of tipped should be easy enough to discern. There is no rule that would assign a penalty to a "tipped" robot for a frame perimeter violation. The vertical projection of the robot is relative to a robot based frame of reference, not a field based frame of reference. This has been stated by the GDC in a Q&A somewhere, but I'm busy and don't want to hunt for it right now. Let's try not to add any more definitions unless we really need them. Bad calls will happen regardless of if we add even more rules or not. |
#8
just my two cents, but the design of the goal is a certain way..
in my opinion, if it passes the plane of the goal opening it is scored, and the counter is as far back by the human player as possible to give them PLENTY of time to get a hold of the ball and get it to the return. imagine if the ball counter was at the very plane of the goal. a lot of the balls that you score would go all sorts of directions and make the human player's job tons harder. i believe that the goal/scorer were designed with this in mind, but that the rules were written with the intention of passing the plane of the goal to be in. of course, that's just my opinion. |
#9
The definition of SCORED is in the first post of this thread and it clearly states that to be scored a ball must pass through the Goal Counter. |
#10
also, the opinion that governs the competition appears to really be the head refs' since they are the ones who interpret the rules and call them differently. the rules were written with a specific intention, but that doesn't mean the intention was explicitly explained in the rules. |
#11
Martin,
The first time I read your post, my thought was "a robot may not possess more than one ball at a time" <G43> ROBOT BALL POSSESSION - ROBOTS may POSSESS only one BALL at a time. Violation: PENALTY. Does this apply or not? I also agree with Kevin, the frame perimeter changes orientation with the floor when the robot is on the ramp. Any determination with respect to the frame perimeter has to be done with this in mind. |
#12
I would just like to say, that despite all this negativity, I had no problems with any of the calls at FLR. We had a great head ref, who obviously knew the rules inside and out.
#13
Wow, that interpretation would have REALLY changed the scores. I saw numerous balls that broke the plane of the goal, but ended up coming back out. At least 33% our autonomous shots did that (gotta adjust that kicker).
#14
The real question is whether a ball inside the goal, on the player side of the plane of the alliance station wall should count even if it has not gone through the counter. It would be folly to assume that a head ref that has a GDC member in the building and the Chief Ref (Aidan Brown) as close as her Blackberry would make such a call in a vacuum. Perhaps this is one of those things that no one expected would happen and will be clarified in future updates. And do adjust the kicker on your bot. Your bot was one of the few that had any chance of scoring while not in the near zone, if not in the goal itself. I think your bot is an example of what everyone had in mind when designing this years game. With the tweaking I know you'll do, not only to your kicker, I expect and hope you will do well at Championships. We'll see you there. |
| SPAM... has it changed your life? (the team or the meat..or both!) | Adare180 | Thanks and/or Congrats | 8 | 13-02-2007 23:03 |
| Regional-specific rules, etc., and do the referees read the rules? | Kit Gerhart | Rules/Strategy | 53 | 18-04-2005 08:51 |
| Andy Baker is the BEST REF EVER | suneel112 | General Forum | 8 | 12-07-2004 01:03 |
| Has FIRST Ever Changed Rules During Nationals? | IMDWalrus | General Forum | 2 | 08-04-2003 15:29 |
| Interpretation of rules | Ben Mitchell | Rules/Strategy | 1 | 09-01-2002 19:53 |
