Go to Post I want to understand the physics. - Molten [more]
Unread 09-03-2010, 21:19
Billfred's Avatar
Billfred Billfred is offline
Team Update 16 applied to 2010 regional data
So out of a Twitter challenge, I went through the data from the Bayou Regional that 2815 and 1398 attended and adjusted it to reflect the five-point win bonus that will come into effect in Week 2 after Team Update 16.
The results are significant; only five of the 38 teams held the same position afterward. (Notably, 1912 retained its top seed.)
I've ignored a few things in my calculations:
-Red cards are ignored, as I don't have a good way to tell who had one when.
-2920, as you may have heard, did not pass inspection until just before their final qualification match. As that match was a 0-0 tie, the new rule addressing their situation would've resulted in no points of any sort. Net result had I accounted for it: 38th of 38.
-Ball penetration penalties, which played no small part in a lot of those 0-0 ties, are ignored simply because there's no way to divorce them from the gameplay that happened at Bayou.
The Google Docs spreadsheet is located at http://spreadsheets.google.com/ccc?k...VTc Gc&hl=en; I welcome you to poke through the data yourself or crunch numbers for one of the other Week 1 events to draw your own conclusions.
Unread 09-03-2010, 21:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update 16 applied to 2010 regional data
Not a public doc -- requested access though.
GitHub
Unread 09-03-2010, 21:26
Billfred's Avatar
Try this:
http://spreadsheets.google.com/pub?k...pg&output=html
Unread 09-03-2010, 21:37
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
But teams might have played differently with the extra 5 point bonus, so I'm not sure the scores can be compared.
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
Unread 09-03-2010, 21:44
Billfred's Avatar
You can't completely do so; there's too much different from Week 1 to Week 2 to do it purely in math. It's all a very rough approximation of the effects.
Unread 16-03-2010, 12:40
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
You are absolutely correct! Why score for yourself when you can willing take penalties (inadvertent rolling on the ball) and end up with the same score at the end.
These changes had a huge impact and shouldn't be evaluated as only statistics in a chart.
Unread 17-03-2010, 00:15
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Attached is the updated sheet for the BAE Systems Granite State Regional. None of the top six spots changed, and the big (+/- 10) changes were in the middle of the pack, where they would have no real effect. The average ranking change was 3.29 places, the median was 2.
Also, note that the "average change" box needs to use the absolute value of the ranking changes, not the average of the changes themselves (which should always be 0).
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 09-03-2010, 22:05
Gabe Salas Jr.'s Avatar
Gabe Salas Jr. Gabe Salas Jr. is offline
Ri3D 1.0
AKA: CrazyBear
FRC #0233
Gabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant future
Thank you Billfred for following through with the challenge - I, too was curious myself
The results are pretty staggering. Would have been nice to incorporate Red Cards - but consider it difficult and moot anyways because of the new update.
"Confidence, not arrogance."
Does your robot use its powers for good, or for awesome?
Unread 09-03-2010, 22:07
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
I just added BAE into a different tab. Feel free to "do the math".
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 09-03-2010, 22:29
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
I've gone ahead and re-done the numbers for NJ. It's a rough estimate like the BAE and Bayou Regionals. There are a couple real big moves in there.
The excel file is here, and it is formatted a bit differently. If anyone wants to convert it into the google spreadsheet format, feel free.
Last edited by jee7s : 09-03-2010 at 23:31. Reason: Made a mistake...see post #10 for corrected spreadsheet
Unread 09-03-2010, 22:59
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Originally Posted by jee7s View Post
I've gone ahead and re-done the numbers for NJ. It's a rough estimate like the BAE and Bayou Regionals, found by subtracting the coopertition bonus and adding in 5 points for each win.
There are a couple real "ouch" rows in there (one team jumped 24 positions in the change), and there would have been a 4 team turn over for alliance selection.
Thanks for the data, but I think you made an error. They did not get rid of the coopertition bonus. They merely added points for a winning alliance. You need to add the coopertition bonus back into the final ranking.
Cold Fusion's 10th Season
Unread 09-03-2010, 23:11
FRC #6357
My mistake on the reading of the team update.
Here's an adjustment...
There are still quite a few big moves in there, and a 2 team turnover for alliance selection.
-Jeff
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 09-03-2010, 23:14
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
I've gone ahead and done KC, and there are certainly some nasty jumps in there. rank changes range anywhere from +/-1 to +/-15. My own team dropped 4 spots.
http://spreadsheets.google.com/ccc?key=0Am5tgDmeNTzGdE1jVFNOVUxjQnB6dmFNUGdpQW5WZ FE&hl=en
Unread 10-03-2010, 07:12
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
One of our students calculated the change for us and 2 rookie teams that were at the same competition with us that we have been helping and noticed that we would have moved up 5 slots. one of our rookie teams down 1 slot and the other up 9 slots. That was at the Kettering District event.
Unread 10-03-2010, 07:29
Dargel1625's Avatar
Dargel1625 Dargel1625 is offline
AKA: David Dargel
Dargel1625 is just really niceDargel1625 is just really niceDargel1625 is just really niceDargel1625 is just really nice
From my understanding of TU-16 the winning team no longer gets double the unpenalized score of the losing team, so wouldn't you have to subtract double the Coopertition bonus out of their adjusted score?
2005: St. Louis Regional Winners (Thanks 1444 + 939)
2006: Wisconsin Regional Winners (Thanks 111 + 1816), IRI Winners (Thanks 71 + 910)
2008: Colorado Regional Winners (Thanks 1296 + 1592) and Engineering Inspiration Winners
2009: Midwest Regional Winners (Thanks 111 + 1675) and RCA Winners, Wisconsin Regional Winners (Thanks 2039 + 2194), IRI Winners (Thanks 68 + 469 +16)
2010: Midwest Regional RCA Winners, Galileo Division Winners and World Semifinalists (Thanks 2056 + 3138)
2011: Midwest Regional Engineering Inspiration Winners
Now on Twitter! @Dargel90
FRC 2010 Team Update #5 Alex Cormier General Forum 23 27-01-2010 13:05
Official Team Update #2! 1/15/2010 Akash Rastogi General Forum 21 17-01-2010 11:34
Problems after 3rd update applied pheisinger FRC Control System 3 13-02-2009 22:47
Regional Data: Tubes scored by each team. Joel J Scouting 11 04-04-2007 21:46
Regional Data archiver 2001 1 24-06-2002 01:40
