Neat demonstration of proportional and PID control systems
A very nice demo that shows the significant improvements to be had using a PID control vs. a simple P control via Makezine's blog. For your consideration when planning your own robot control system Cheers, Joe J. |
Re: Neat demonstration of proportional and PID control systems
Don't sell yourself short - I've seen some pretty amazing PID applications in FIRST. Remember that response is both torque and mass dependent, and as far as that goes he has a huge advantage (high torque for very low mass) that allows his motions to be much quicker than ours.
IMHO, his tuning needs a bit more work. There is still a bit of overshoot or ringing in it's motion. I'll bet it can be tuned even better. |
P and I aren't that hard to implement with some testing. D is hard to wrap your mind around a lot of the times as a newer programmer.
P helps make sure you get near your target, and decelerate as it approaches it I makes sure you reach your target but overshots and undershots if gains are incorrect. D is hard to explain. |
P gives you fast dynamic response. I gives you steady-state accuracy. D allows P to be set to a higher gain for even better dynamic response. (D can remove some of the overshoot caused by high P values). ~ |
#7
Think "D is for damping". It is kind of like software friction. It always acts in the opposite direction of motion, and is proportional to how fast the object is moving. The faster the object moves, the more the D control tries to slow it down. This helps to settle out oscillation and remove overshoot.
#8
I love PID controls. Back in college, I had a project where I balanced a vertical bar mounted to a bearing on a swinging arm (like balancing a ruler in the palm of your hand). You could hit that bar all day and it would never fall over. Too bad my students were not interested by my retellings of that project. Maybe this video will spark their interest and show the benefits of PID controls (especially in the context of autonomous drivetrains). Thanks for sharing!
#10
What I hate about PID control is that it allows the guess and check method of control without really coming up with a conclusion of why you tried certain values. It completely eliminates the analysis portion of closed loop feedback -- analysis that could fundamentally improve even the mechanical side of the design.
Aside from that fundamental flaw, yes PID is good enough for FRC. Who has the time to truly model a subsystem in FRC anyways? |
| PID Control | Geek 2.0 | Programming | 16 | 12-01-2010 21:10 |
| LabVIEW Training and new control system demonstration 10/17-10/19 in Frazier Park, CA | Joe Ross | NI LabVIEW | 0 | 25-09-2008 13:25 |
| PID Control | John Gutmann | Programming | 12 | 15-04-2007 18:52 |
| PID Control | Chris Bright | Programming | 9 | 26-03-2005 19:44 |
| Proportional Control | ShadowFlame | Programming | 0 | 14-02-2004 11:53 |
