Go to Post That inspector needs their hard drive wiped and the common sense upgraded from version dingbat 1.0. - Andy Baker [more]
Unread 16-03-2010, 09:13
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Camera Communitcation Problem
Our team went to the Wisconsin Regional last weekend and our robot communication actually went pretty well. The camera, on the otherhand, only sent signal if we powered the robot on after FMS was connected on the driver station. This happened two times in a row so after that we pleaded with the field volunteer to let us wait until the Field control turned on communication.
The only problem with this is that they were getting pretty aggrivated with us, and we do not want to get any penalties for this so was anybody else having these problems, and if so, how did you fix them? Thanks
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 16-03-2010, 18:32
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Camera Communitcation Problem
what do you mean "Turned on communication"? As in when the system resets for the new match?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 16-03-2010, 21:15
What language are you using, and are we talking about vision to the DB or vision processing on the cRIO?
Greg McKaskle
camera problem frcchile Electrical 10 22-02-2010 15:32
Camera problem ijk90825 Technical Discussion 1 28-01-2009 01:35
Camera Problem ta1234 Programming 1 29-01-2007 09:38
camera problem miscar Programming 2 23-01-2005 12:06
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
