Go to Post A rule is a rule is a rule. - Cory [more]
Unread 16-03-2010, 13:18
Chris is me's Avatar
AKA: Pinecone
pic: 2791 At WPI
Unread 16-03-2010, 13:23
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 2791 At WPI
Originally Posted by Chris is me View Post
We mysteriously lost the ability to climb over the bump. We have no idea why, we don't tip or anything, we just don't go over.
Chris, the bot looks good! Strangely enough, we lost the ability to climb over the bump between ship day and our first regional. We think the reason is two fold for us. The first part of it is because our drive chains are routed in such a way that does not allow for proper chain wrap on the center wheels so the chains can jump under high stress (cresting the bump). The second part may have been due to the way the carpet was mounted on our practice bumps, because apparently our carpet was mounted one way and the carpet on the field was mounted another. (This was told to me by another mentor on the team so I don't know much more than that) We have a solution for it, that I'm sure you guys are more than capable of implementing since your drive seems to be nearly identical to ours. PM Me if you want to know more...
-Dustin Benedict
Unread 16-03-2010, 13:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Nice!
The bump problem is probably due to the interesting things that happen with 8wd and the center of mass of the robot, and the angles at which the forces work when the bot is at a 45 degree angle.
I suggest you draw a free body diagram of the robot in the position where it gets stuck, and figure out the tractive force on each pair of wheels, and compare it to what is needed to get over the bump. Might be that adding some weight at one end of the robot, down low, will fix the problem.
Unread 16-03-2010, 13:54
AKA: Pinecone
Originally Posted by squirrel View Post
Nice!
Hmm. As we moved around all the heavy stuff, this explanation makes a lot of sense. Since I can't calculate the CoG (something about the robot being crated), I think I'll do the math with various weights, locations of the center of gravity, etc. and see if putting a bunch of weight on the front or back would fix it. While planning specifically where to put weight isn't possible, doing the math should help me figure out how to fix it on Thursday at CT.
Unread 16-03-2010, 14:14
MrForbes's Avatar
AKA: Jim
You should be able to make a close approximation of the CoG by just sketching the robot, and estimating the weight and location of each major subassembly. Then draw a FBD, and look at the normal force on the wheels, and calculate the tractive force using the published CF specs for the treads.
Unread 16-03-2010, 14:58
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I still love your bot. That 8 wheel drive is really nice. I hope everything works out for you guys in CT because you will certainly be a force to be reckoned with there. Good luck!
pic: 2791 Completed Drivetrain Chris is me Extra Discussion 6 13-02-2010 14:15
pic: 2791 Teaser 1 Chris is me Extra Discussion 18 26-01-2010 16:20
pic: 2791 Final robot yodameister Robot Showcase 13 21-02-2009 23:45
pic: What is 2791 up to? yodameister Extra Discussion 10 02-02-2009 18:21
pic: Rookie 2791 progress yodameister Extra Discussion 10 27-01-2009 21:45
