Hey All! I need some more help
I was working on the program today and after programming my solenoids I built the program and ran it has startup on the robot. Well I logged into FRC driver station and it is switching between Teleoperated enabled and watchdog not fed. How do I fix this? it is a slow alternating maybe once every second.. Thanks guys! |
Re: switching between Teleoperated enabled and Wathcdog notfed
From that evidence I'd say you have a section of your Teleop that takes a long time to complete, usually a loop or a timed delay, and the Watchdog is not being fed on a timely basis.
The solution depends on how the delay is being caused. If the delay is too long, then your driver controls will also respond slowly and that can be a danger. That's sort of what the Watchdog is intended to warn you of. Last edited by Mark McLeod : 19-03-2010 at 20:09. |
Well here is what I am attempting to do. I want solenoid one to open and then stay open for a length of time, and then close. and then I want solenoid 2 to ope. immediately after solenoid one closes. in turn it will make the kicker(our cylinder) go out and then come back in before two seconds so we don't get the penalty for having something outside our framer perimeter for more then 2 seconds. Thanks
You could write this as a state machine in Teleop.vi or you could write it as a sequence in Periodic.vi
It's probably clearer to visualize as a sequence structure in Periodic.vi |
As for "sequence in Periodic vi" I'm not as sure. Here's what I think you mean, in pseudo-code (with line numbers for reference): 10 loop: 15 loop1: 20 watchdog_delay_and_feed(some reasonable polling value, say 40ms?) 25 if you haven't received a kick command from teleop, goto loop1 30 do something here 35 watchdog_delay_and_feed( 2 seconds) 40 do something else here 45 clear the kick command 50 goto loop Is the above a possible implementation of what you are suggesting? If not, could you give more details please. If so, I have some questions/comments: The infinite loop (lines 10 and 50) means that this task never terminates. So in that sense it's not "periodic", even though it uses the "machinery" of the periodic vi in the framework. true? The watchdog delay and feed in line 20 is required so that this "periodic" task does not consume all the CPU resources. It releases the CPU to go do other things. The RTOS recognizes this command as an opportunity to take resources away from this task and use it for other tasks. Is this anywhere close to true? How does the RTOS know when to return to this task? Does the "watchdog delay and feed" command cause the RTOS to suspend the task and set some sort of timer event to wake it back up again? What's the best way to pass a "kick command" (lines 25 and 45) to this task? Some have suggested using a simple global boolean. What are the benefits/drawbacks of doing this? What are the advantages of using other approaches? Our team is brand-new to LabVIEW this year, and they have zero prior knowledge/experience with real-time control. I am trying to teach them some fundamentals in language they can understand, but I am hampered by the fact that I know absolutely nothing about LabVIEW and am having difficulty relating it to the real-time knowledge I already have from working with embedded reatime projects using assembly language and C. Thanks. ~ |
You have the essentials in your pseudo-code example.
There is one point that differs and that's with the use of the Watchdog. The Watchdog should not be fed in a periodic loop. That'll end up defeating the purpose, in that the Watchdog will become a Watchdog only for that one Periodic task and not for anything else. It would never time out anywhere once you get your Periodic loop running properly, since this is a parallel task. The Watchdog should be constrained to the primary Autonomous and Teleop data paths or sub vi's of those. Instead a Timer vi is used. At the conclusion of the Timer it goes back on the OS task queue. No long loop anywhere in our code should run unconstrained. They should all have at least a 10ms timer delay, so they don't prevent other concurrent actions. This has been the cause of many "sluggish" controls complained about by teams (it's the field's fault ).I knocked off an example (untested) to illustrate the point in a LabVIEW context. It includes two different ways to "kickoff" the sequence:
The Periodic Tasks vi does not get called periodically, it's only called once and the loops define for themselves what the period is for each parallel task within that vi. Last edited by Mark McLeod : 21-03-2010 at 14:54. |
#7
I was somehow stuck in the mindset that the period was controlled by the RTOS. I suppose if I had actually learned a little LabVIEW it would have been obvious. Your comment about not feeding the watchdog also makes perfect sense. Now, about the Timer vi: when LabVIEW encounters a Timer vi in TaskA, it generates code that suspends TaskA? So the CPU is then free to go service other Tasks that are waiting to execute? And a timer is set by the RTOS to alert it when it's time to go back and service TaskA? (or some logically equivalent mechanism?) If all the above is correct, it sounds like cooperative multitasking, and I'm trying to imagine how the framework manages task execution when there are several "periodic tasks" with different periods. I had somehow imagined that these would be preemptively serviced in a rate-monotonic fashion, but I guess that's not what happens? For example, let's say there are two periodic tasks: TaskA 5ms TaskB 100ms ... and TaskA takes 2ms to complete (40% CPU usage), and TaskB takes 30ms to complete (30% CPU usage). That's only 30+40=70% CPU usage, and yet TaskA will not run at 200Hz because it cannot preempt TaskB which takes 30ms to run. Is that correct? ~ |
#8
The multi-tasking LabVIEW environment gets even more complicated when you recognize that vi's are operating in parallel and in fact operations within vi's are also operating in parallel.
There's nothing unique about Periodic Tasks.vi that's given it and all the tasks within it priority over Teleop.vi or Vision Processing.vi, etc. In my example posted above the four Refnum Gets are all parallel tasks synchronized only by the While loop data tunnels. Everything's clamoring for scheduled CPU time and somebody's going to have to wait sometime. It's non-deterministic in this framework. There are some low-level non-RT calls made too, but for our FRC purposes think of it as close-to-RT. The timer alerts the task scheduler when it needs servicing again. In fact you can use a timer with zero time just to break a task out of the CPU and send it to the back of the scheduler queue. Last edited by Mark McLeod : 21-03-2010 at 16:49. |
#9
I'm responding for the masses too
#11
Understood. And in that spirit, one more question: if the user creates a periodic task with a 5ms timer, and the code in the task takes 1ms to run, is the period of the task 5ms or 6ms? In other words, does the Timer vi count down from the time the task was started, or from the time that the timer vi is executed?
| Problem Switching Between Modes | Powerhawks Team 1111 | frenchie4111 | Programming | 4 | 19-01-2010 08:44 |
| Autonomous and Teleoperated | Technic-R-C | General Forum | 8 | 15-02-2009 16:04 |
| Switching between Autonomous and Teleoperated | Technic-R-C | National Instruments LabVIEW and Data Acquisition | 3 | 07-02-2009 08:55 |
| Autonomous and Teleoperated | Technic-R-C | NI LabVIEW | 2 | 06-02-2009 22:19 |
| Switching between Hybrid and User-Controlled | Zyklon | Programming | 3 | 13-02-2008 08:30 |
