pic: Soccor balls stuck on ball return
Re: pic: Soccor balls stuck on ball return
It turned out (from what I saw) that a ball was ripped, and so got caught in the ball return. Our human player tried pushing the balls as fast as he could down the chute, but nothing worked.
We ended out replaying the match. And of course hanging again (as you can see ) |
really? i heard on the webcast that it was cause some teams had some duct tape type of substance on their robot that rubbed off on the ball causing them to get stuck. oh btw good thing there was a replay, i was afk for the original XD
And the first match was more exciting (7-4 instead of 5-1) |
It's amazing how just a little bit of tape or ripped ball can cause a jam like that, especially when a couple of more balls fail to unjam it. Is this the only case of something like this happening?
There were two cases of this at Cass.
One was user-induced when a robot's hanger mechanism stopped a ball from coming off the return (and generated penalties). The other was caused when a faster-moving ball caught up with a slower one on the return, and the friction between the two ball surfaces caused them to slow down even further. The first ball dropped into the gap between the end of the return and the tower crossbar. <G18> was applied. |
#7
Well, I found out today what the case was.
Apparently one of the teams had some sticky stuff on their gripper/kicker mechanism that managed to adhere to the ball, which caused the ball to slow down on the way down the ramp and get stuck in the space in between the ramp and the hanging pole on the tower (since the ball didn't have enough velocity to just simply bounce down). GooGone did the trick of getting rid of the sticky stuff on the ball . |
#9
That's what it's all about. |
#12
Are they stuck because the hanging 'bot has distorted the tower's geometry?
#13
Isn't this covered by <G18>?
#14
As noted above, they were damaged pre-ball return Last edited by Alex Dinsmoor : 19-03-2010 at 22:25. |
| Ball Return Worries | indubitably | Rules/Strategy | 12 | 07-03-2010 16:02 |
| Ball Return Time | GKrummel | Rules/Strategy | 1 | 16-01-2010 14:26 |
| Ball Return | frank.pendzich | Rules/Strategy | 11 | 11-01-2010 09:19 |
| Balls getting stuck in hopper | FTtyler | General Forum | 30 | 09-02-2006 20:57 |
| Low Priced soccor balls | mnkysp6353 | General Forum | 0 | 08-01-2002 20:58 |
