Go to Post When motors stall, bad things happen. - Rob Stehlik [more]
Unread 21-03-2010, 21:20
ggberg's Avatar
ggberg ggberg is offline
Mechanical/Web
AKA: Gil G
FRC #1683 (TechnoTitans)
ggberg is on a distinguished road
In need of 2 Solenoid Valves
I'm looking for (2) 3-way solenoid valves, 12vdc or 24vdc rated 125PSI
Does anyone know of a supplier for the valve as well as a part number?
We are hoping to get them before the Championship but our current supplier does not carry them.
Thank you for any help!
Team 1683
Mechanical/Web
TechnoTitans.org
2010 Peachtree Regional Champion.
2010 Peachtree Regional Creativity Award.
Unread 21-03-2010, 21:32
Mr_Fred's Avatar
Mr_Fred Mr_Fred is offline
Mentor 3394
FRC #3394 (Knight Riders)
Mr_Fred is an unknown quantity at this point
Re: In need of 2 Solenoid Valves
If You have a Motion Industries in your area, they carry Festo Valves
of all types...
Mr_Fred (Mentor 3394)
Unread 22-03-2010, 08:21
Generator of Entropy
FRC #2973 (The Mad Rockers)
There is an SMC distributor in Norcross:
Flodraulic Group-Atlanta
1790 Corporate Drive Suite 330
Norcross, GA 30093
Phone: (888) 925-8935
Fax: (770) 925-4207
http://www.flodraulicgroup.com
The part we used is SY3220-5LOU-N7-S; you will also need to buy one fitting for the input side (the outputs already have 1/4" tubing QD fittings), which is part number KQ2H07-M5.
The 5 in the part number is 24V; same part number with a 6 is 12V.
Here is the SMC webpage where you can see the options for this valve series.
Here is the catalog, which you will need to print the sections that show the flow rate and orifice size to the inspectors.
Here is the information you will need to show that they are rated to 125 psi.
Need help with SMC solenoid valves Ed Law Pneumatics 6 04-02-2010 06:43
How to wire solenoid valves???????? JCODER Pneumatics 3 31-01-2008 20:11
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 05-02-2003 17:21
Cylinders + Solenoid valves Greg General Forum 2 28-01-2003 09:29
