Robot Communications at the Championship
I'm sure FIRST has got this covered, I'm just interested so I thought maybe someone could shed some light on this subject:
with 4 fields running simultaneously fairly close to each other, is it necessary to set up the communication in a special way to avoid communication problems? if so what do you imagine (or know) this configuration to be? would a WiFi expert look at this setup (24 robots running simultaneously on 24 different networks) and see a potential problem, or would he shrug it off as a non-issue? I'd appreciate to learn more about the advantages and limitations of the 802.11n protocol and the configuration used. -Leav |
Re: Robot Communications at the Championship
Not having been there, I can't say for sure, but I believe CMP runs the fields one at a time, running one while the others are resetting. Also, in my experience 802.11 is fairly forgiving of multiple networks sharing channels in close proximity.
Nope, it's 4 fields simultaneously. Or pretty darn close, depending on match schedule and how far ahead or behind each field is schedulewise.
| Robot Communications dies as Motor speed increase | Michael Fadaie | NI LabVIEW | 4 | 19-02-2010 00:55 |
| No Robot Communications | alex42 | FRC Control System | 4 | 10-02-2010 20:42 |
| No Robot Communications | Team2191 | FRC Control System | 1 | 22-01-2010 20:12 |
| [FVC]: Transporting your robot to the Championship | nonother | FIRST Tech Challenge | 14 | 31-03-2007 01:40 |
| Communications via the Programming Port | Larry Barello | Technical Discussion | 9 | 10-06-2003 23:33 |
