Go to Post The best we can all do for our kids as parents, mentors and world citizens, is to model [Gracious Professionalism] always: not to win an award, but because it is the right thing to do. - chapman1 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-04-2010, 10:56
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Robot Recycle
Hello,
As a rookie team we destroyed many parts of the robot.
1. The main module of the Crio is broken but working.
2. The camere looks bad but working.
3. 1 Digital SideCar is half working (some DIO's are not working).
4. The compressor is broken.
5. The preasure switch is not caliberated.
What should we recyle from this year's robot?
I think the Crio and, router and the camera.
but unfortunatly some of this are not in it's best condition to work for many years. what should we do? I am aware that some of this things won't be in next year KOP.
Unread 01-04-2010, 17:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Robot Recycle
Originally Posted by yarden.saa View Post
Hello,
Try to not do that.
A rookie team gets one cRio and one compressor, and you are expected to use them again next year. Possibly the camera as well.
By allowing them to be "destroyed", you've cost the team a considerable sum. (By "you" I mean the team, not you personally). Take this as a lesson that had to be learned the expensive way: Take very good care of your things, otherwise you won't have them anymore.
Better start fundraising.
Unread 01-04-2010, 17:33
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: Robot Recycle
Definitely reuse the camera. If it just looks bad, design next year's robot to hide the camera.
Also, reuse the pressure switch. Just calibrate it for next year.
As far as your cRio, if it works use it. If it doesn't work, see if it is under warranty.
Try to be gentler on the parts next year. It pays off over time.
Unread 01-04-2010, 19:20
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
Re: Robot Recycle
Don't throw the side car away. Make sure you document what DIO's are not working for next year and keep it for prototyping.
Here is this year's comparison between the veteran and rookie KOP. This year, veterans got 1 digital side car instead of two. Here is the KOP checklist http://usfirst.org/uploadedFiles/Com...klist_RevC.pdf.
You can reuse most of the stuff. As long as you can get the parts commercially during the season, you can use them. Many of the motors can be reused as long as they have not changed the model. CIM's usually don't change, the smaller motors often do. You have to check carefully. We also write the year on all our parts. It's ugly, but it keeps us legal.
I know you have figured this out already, but next year protect those electronics. Of course, I say this after I let the team delay putting a rollbar on the prototype. They were so eager to try the bump. We all just stood there and watched it tip. We took out the digital IO module that way.
In case you have an extra $750 dollars sitting around (haha) you might want to think about getting a second cRIO. They are 1/2 price for FIRST teams.
Recycle your old Vex hardware to new teams Foster VEX 0 19-04-2008 08:39
RECYCLE FIRST - NJ Regional slickguy2007 General Forum 1 24-02-2007 18:49
Ideas for Pneumatics Recycle Can-Crusher Needed geo Pneumatics 5 09-04-2003 18:25
Pneumatics Recycle Can-Crusher Lethi86 Pneumatics 24 07-11-2002 12:13
Pneumatic Recycle Can-Crusher Lethi86 Championship Event 5 15-05-2002 00:25
