Go to Post Build a GREAT robot (just not as good as mine). - Steve W [more]
Unread 07-04-2010, 01:03
Gearbox Maximum Torque
Disclaimer - I am an electrical guy, please excuse my ignorance.
Some of the students prototyped a lifter mechanism that featured and subsequently destroyed a P60 132:1 gearbox. The final planetary stage was almost entirely bald.
It is easy to gut-feeling see why it broke in retrospect, but I'd like to be able to teach them how to predict this ahead of time. Trouble is, I couldn't find any specification on this gearbox that would give me a good place to start.
What is the name of this 'max torque' spec that I am looking for, and where do I find it? Is there a collection/spreadsheet of this info for common FRC gearboxes?
Thanks!
PS: If it helps you understand the number I want: I'd measure this by stalling one side of the gearbox and cranking on it with a torque-meter until it broke. Does this number change with speed?
PPS: What other info am I missing?
Unread 07-04-2010, 01:17
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Gearbox Maximum Torque
Here is Dr Joe's recommendations on the 42mm Banebots gear boxes, which where the predecessor to the P60 model. I don't know about any for the P60.
Are you using a FP motor or on of the RS-555 motors?
Keep in mind the FP can generate significantly more torque than the RS series motors the P60 was designed for. It does work with the FP but you have to be careful how you use it because there is a risk of destroying the gearbox (which unfortunately you now have first hand experience with). I am also electrical/programing so that is the extent of my knowledge
Robot Inspector
Unread 07-04-2010, 02:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Many people would argue you could have predicted it's failure when you saw the "Banebots" sticker on it. The brand has become somewhat notorious for poor design, workmanship, and material quality. Although, I cannot comment on that specific model, so I'll leave it at that. Perhaps things have improved since those days.
To better answer your question, yes, the failure of a gearbox can absolutely be predicted. The problem can be approached a few different ways:
- All factors and loads known/given, lifetime to be found
- All factors and lifetime given, maximum load to be found
- Lifetime and load given, design/sizing of the gears to be found
After a machine design course spending a few weeks on gear train design, it is not a terribly difficult process to analyze a gear train, but it does take a little while. There's probably about a dozen pages in my notebook that run through all the calculations.
Also, in gear train design, there are a lot of "fudge factors." Usually they are referred to as "K factors." There are about 8 or so of them that deal with temperature, gear quality, mounting configuration, lubricants, etc and can greatly affect the design and calculation of the gear train. Many times, these K factors cannot be calculated and must be estimated. So, while the failure (or success) of a gearbox can be calculated, its lifespan is only estimated to some reasonable degree of certainty. Typically in engineering design, when we talk about lifespan, we're talking greater than 10^4 cycles. For your application, you're just concerned with if it will work for your robot.
Honestly, I've never done the above calculations for a FIRST Robot. There just isn't time to fully analyze everything. Over time, you just learn what works, and develop a rule of thumb, and build off past designs. If you're concerned, you throw it into FEA to give you a rough idea if you're screwed or way in the clear.
To determine the safe loading for that gearbox, the easiest way would be a destructive test, like you mentioned. Lock one side, put a torque meter (digital torque wrench perhaps, rod and weights?) on the other side, and have at it until something breaks. If you wanted to, the maximum safe load could be calculated, but you'd need all the gear pitches, tooth counts, material, face width, hardness, etc.
There is not any listing I know of that indicates the maximum allowable torque for common gearboxes used in FRC.
Unread 07-04-2010, 03:06
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Look on the vendor's spec sheet for the gearbox. If there is no spec for it, caveat emptor.....
64:1 is a steep ratio for a gearbox, 132:1 is asking for trouble if the thing is heavily loaded (as a lifter would be)
Unread 07-04-2010, 19:26
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
Team 48 was going to use a 256:1 Banebot planetary. I was looking around in the North Carolina pits, when I happened into their area. I noticed them installing a hanger for the vertical bar, but I didnt see any motors or transmissions. When my team and I was working on a hanger we found a really nice 40:1 wormgear... but it was too pricy. Well, back to 48. Upon further inspection I saw they had a Fisher-Price and a parallel silver gearbox. I had never run into Banebots transmissions before this point, probably due to their reputation. There was a small orange sticker on that thing and I was fairly shocked about the reduction... until that moment I didnt think it was possible to cram such a small reduction into a small transmission.
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 07-04-2010, 21:02
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
It was only 4 stages of 4:1.
But, Sadly we had to remove the whole system when we found out our nice clean 'ground down' welds snapped under the forces required pull the robot up. Note for next year don't grind welds to make them look 'pretty'.
And yes you can figure out the maximum torque of any gearbox you just need to apply the principles of machine design and properties of materials to determine the physical properties of the material the gears and shafts are made from and then the actual max stress that can be absorbed by the gears and shafts and apply a factor of safety to insure the parts never break.
Unread 07-04-2010, 21:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Failure modes matter. Is it a shaft bending, teeth shearing off, etc.
It is hard to know from your description what happened. The gears teeth may have been a secondary failure.
But... ...once you know how it fails you can estimate at what value it will break.
It is probably outside the scope of a ChiefDelphi.com thread to cover the HOWs of these estimates. But perhaps we can give it a shot once we know more about what failure we are trying to predict.
Joe J.
Team #88, TJ2
Unread 08-04-2010, 00:04
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
But it's fun (and a good educational experience) to dig into the HOWs!
http://www.bostongear.com/pdf/gear_theory.pdf is a wonderful reference for gear theory. See page 6 of the PDF for the Lewis formula (Barth revision) for safe static stress on gear teeth, for example. Given the face width, diametral pitch, pitch diameter, pitch line velocity (or RPM), and material, the formulas and tables on that page will give you the max torque a gear can take (at least on the teeth).
Unread 08-04-2010, 09:17
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks for the reference.
I didn't mean to imply that we can't get into the HOWs a bit but I just wanted to be clear that ChiefDelphi.com is no substitute for an in depth engineering class.
And... ...Don't get me started on the Lewis formula! It is a good starting point but it is clearly too conservative for many many applications (including every FIRST robot I have ever encountered).
Bill Beatty and I agree (I can't find the thread but trust me, he does) on this point -- a simple beam bending stress calculation is a more appropriate estimate for FIRST gear teeth.
Joe J.
Team #88, TJ2
Unread 08-04-2010, 10:53
Dick Linn's Avatar
no team (Synergy)
It may not be relevant, but the Banesbot max recommended torque is 85 ft-lb for all the larger P80 Series Gearboxes
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 08-04-2010, 11:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Norm,
Two important questions that might help us determine failure mode:
1. What was the diameter of the spindle you were winding onto?
2. Did you support the opposite end of the shaft with a bearing block, or was this a 150 lb cantilevered load on your gearbox?
Second question is the more important, as 150 lbs of side load on one of these gear boxes is probably going to translate through the output bearings and put a heck of a load on the final planetary stage.
Also, if only you'd have mentioned this while you were at Lone Star. I'd have loved to take a look at the thing in person. If only to determine whether I should continue to assume these gearboxes are really a vast improvement over the '07 ones my team had welded back together at GLR.
Unread 08-04-2010, 11:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Joe J.
As Joe is eluding to, the cycle count and service life are quite low for FRC robots.
Last year 217 saw around 100 matches. At 2:15 minutes per match, it is less than 4 hours of runtime. Even at the 4500 rpm (cim speed) this is only 10^6 cycles. This is relatively low in terms of most design lifes, but within the fatigue regime of design. Really though the initial stage is seeing the lower torques. With a 50:1 or more, you are now down to 2x10^4 cycles. This is down within the infant death for most powertrain systems.
Thus I tend to agree with Dr. Joe that design so that the teeth do not yield, and you should be good to go.
Hmmm. maybe a simple set of equations would be good for this and helpful to the community.
IKE
Unread 11-04-2010, 21:23
Here's another calculator that I've been using lately. It sounds like it's an online version of what's referenced in that document.
http://www.rushgears.com/Tech_Tools/horsepower.php
Unread 07-04-2010, 21:38
Heh. The quality of the P60 is significantly greater than the commonly failing gearboxes from 07-08. (Oh jeez...the horror of replacing those as a freshman... )
Unread 11-04-2010, 23:27
dtengineering's Avatar
AKA: Jason Brett
The last part of this statement, which I have placed in bold, is the most important part.
I hope everyone gets a chance to check out a P60 gearbox and see just what awesome little machines they are. I also hope they get a chance, at some point, to talk to the people at Banebots, who are committed to quality and customer service and stand behind their product 100%.
We've had BB gearboxes on our robots for years now, including a 26:1 P60 (which we modified to a 20:1 and then a 16:1 just by changing a few inexpensive parts) on this year's machine. The ONLY time a BB gearbox has ever failed us was when an overseas supplier sent insufficiently hardened output stages for use in the "Rack'n'Roll" KoP. Banebots responded to that problem by rush manufacturing replacement plates and shipping them -- for free -- to every FRC team whether they needed them or not. An unfortunate incident, perhaps, but one handled with class, grace, and an abundance of care for the customer. To my knowledge not a single one of the upgraded gearboxes failed. <Edit: I have been informed, by a most reliable source, that there were a few that did, due to a machining issue in the replacement parts.> And yet Banebots went and redesigned the entire thing into the P80 gearbox to make it even more durable.
The previous small gearboxes, manufactured overseas, were not of the same construction quality as the "Made in the USA" P60's, but still served us well in many applications including the Poof Ball shooter on our "Aim High" bot, which has outlasted two FP motors and is still happily firing Poof Balls about our shop these days. Yes, we took time to grease them, and no, we did not use the gearboxes for high impact loading or high-torque applications. Although we have a 256:1 on the shelf, I think 64:1 is the highest reduction we ever used.
Any gearbox will fail if you subject it to extremes of loading beyond its design specifications. For years Banebots made this very clear with their high reduction gearboxes, reminding customers that the highest gear reductions should be used more as a way to reduce speed, than a way to increase torque. It's probably a reminder worth putting back up on their website. And it's probably worth it for them to sacrifice a few gearboxes to a torque test and publishing that value, too. (Impact loading, as in an arm or large spinning mass suddenly reversing direction, would be a bit more difficult to measure.)
The good news is that they sell spare parts, and if you give them a call they should be able to tell you exactly what you need to get that P60 back up and running.
The bad news is that statements such as the first half of this quote are unfair to a company that has produced a solid, reliable line of small, low-cost gearboxes for robotics hobbyists for years. Some of their previous, less expensive gearboxes haven't been as pretty or as well made as the P60s are, but they worked, and worked well when used with respect for their small size and low cost. Banebots has stood behind their product, even at considerable expense, and their products have enabled us to build better robots than we could without them.
They deserve better than snide remarks.
Jason
Fisher Price Gearbox Torque zaphodp.jensen Motors 12 25-01-2010 12:45
Cim/planetary gearbox torque?? Bruceb Motors 3 08-02-2008 11:01
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
