Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 14-04-2010, 22:28
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Video Encoding Guidelines
With many teams posting videos online, I'd thought I would share some helpful tips to make them look at good as possible.
  • Try not to repeatedly re-encode video files when transferring them to different programs. Each re-encode makes the video look more "blocky" and pixelated. Think of making a photocopy of an already photocopied page. Each time you do it, it looks worse.
  • Try not to convert the framerate of the videos. Changing a 30fps video into 60fps just duplicates frames for no reason, and changing it to 24fps will likely make it "stuttery", as some frames will be removed. *This is not the same as changing the playback speed, like in high-speed/slow-mo video*
  • If you are all done editing your video, export it as high quality! Try not to scale your video down *or* up. Both cause a loss of quality. Also, you generally shouldn't select some generic "Web" preset! It will likely over-compress your video and make it look bad! You should always upload the highest quality "final release" video to sites like YouTube! (See notes below)
  • Don't add your own letterboxs or pillarboxes! These are those "black bars" you see on widescreen movies when watched on a regular 4:3 "square" SDTV, and when you watch SD video on a HDTV. Sites like YouTube automatically add them in when you watch on their site. Adding your own just adds more empty black space.
I use an older version of Final Cut Express, and mainly work with only SD content. The camera I have isn't that great to begin with, so I try to retain as much quality as possible by exporting the final project as a full quality DV file, and I upload that to YouTube. YouTube then converts that into a variety of formats (FLV, H.264, 3GP) for use on its site. You should try exporting to DV, MPEG2, or H.264. The last two are the formats used on DVDs and HD content like Blu-Ray discs.
Also, if you are hosting your videos on your own site, you should convert you video using something like Handbrake (Free, Open Source, Win/Mac/Linux) to convert to H.264. The "Universal" preset should work well after checking the "Web Optimized" box. The resulting file can be downloaded and viewed in a player, and can even be streamed in a Flash video player you can place on your site.
See Also: http://www.google.com/support/youtub...&answer=132460
Anyone else have other comments/suggestions?
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
SOAP Video Encoding Errors ham90mack General Forum 32 23-04-2007 16:53
General guidelines Mike Martus OCCRA Q&A 0 10-09-2003 20:32
Curious...Video Encoding archiver 2001 2 24-06-2002 03:01
Yearbook Page Guidelines Anne Lam General Forum 1 12-01-2002 23:37
