Go to Post "at some point in the next six weeks you are going to start feeling like you are involved in a robot building contest. Then you are in serious trouble" -Dean Kamen - KenWittlief [more]
Unread 29-04-2010, 17:44
The Analog's Avatar
The Analog The Analog is offline
AKA: Aaron Swope
FRC #0079 (Krunch)
The Analog is an unknown quantity at this point
Send a message via AIM to The Analog
Parallax and speed controllers
Has anyone use a Parallax basic Stamp/SX/Propeller micro-controller to drive a Jag or Victor? And if not do you think it would work?
Unread 29-04-2010, 18:06
Re: Parallax and speed controllers
Wow, that Propeller thing is... unusual*.
The propeller claims to be able to do 40mA per pin, you can probably do it by just putting a ~330Ohm current limiting resistor in series. If you are having trouble, consider putting a buffer in between.
You can see how the digital sidecar buffers its signal on page 3 of http://usfirst.org/uploadedFiles/DSC...matic%20v7.pdf
Then it is just a matter of creating your PWM signals, which should be relatively straight forward.
* This document was my introduction to it. Wow.
Unread 29-04-2010, 18:20
The Analog's Avatar
AKA: Aaron Swope
FRC #0079 (Krunch)
thanks for the link to the Digital sidecar, that really helps.
Unread 29-04-2010, 18:25
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Basic Stamp will drive a Victor, so the propeller chip should also work.
There is huge forum for all things Parallax. Some digging came up with this post http://forums.parallax.com/forums/de...?f=25&m=369650 that has code attached to it.
As always Google is your friend!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 30-04-2010, 00:43
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
I once used an arduino to test our victors/jaguars once. It was great. It was fast and simple.
All i had to do was use the old <ServoTimer1.h> from ladyada and use the following code. http://www.ladyada.net/make/mshield/use.html
#include <ServoTimer1.h>
ServoTimer1 servo1;
ServoTimer1 servo2;
void setup() {
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Servo test!");
  servo1.attach(10);
  servo2.attach(9);
void loop() {
  Serial.print("tick");
  servo1.write(180);
  servo2.write(0);
  delay(1000);
  Serial.print("tock");
  servo1.write(0);
  servo2.write(180);
  delay(1000);
Unread 30-04-2010, 07:49
Aaron,
The RC was originally a Basic Stamp in a special box and programmed in PBasic.
Unread 30-04-2010, 10:12
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Though in that case, the Stamp was running the user code, there was still another controller that handled all the PWM signals.
Oh, those were the days. 26 Bytes of RAM. Though there were a few bits here and there that you could use in an emergency.
Working on the Stamp based RC got me a job at Parallax for an internship.
A note to the OP. I'd recommend getting something like a serial servo controller, which allows you to deal with mutiple Jag/Victors using only one or two pins for serial communication. If you are using something like a stamp to control them directly, you may notice minor delays that can affect steering, since the control signals are not updated exactly simultaneously. Also, without the SSC, you have to constantly refresh the output signals, which makes the code architecture slightly more difficult. It can certainly be done, but the $30 add-on really makes it easy and powerful.
Can we use old Relays and Speed Controllers? thoughtful Control System 14 17-01-2005 14:55
Can we use old Relays and Speed Controllers? thoughtful Electrical 14 17-01-2005 14:55
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
1999 Manual, Speed Controllers, and Breakers Venkatesh Electrical 4 03-02-2004 21:53
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
