Go to Post We can not close our eyes, ears and minds from March to December. - Dave Campbell [more]
Unread 11-05-2010, 15:53
Schuyoff Schuyoff is offline
FRC #2904
Schuyoff is an unknown quantity at this point
downloading issue
Hi i can connect to the cRIO and "download" but i don't think that it is downloading my program to the right place. when i right click the .out file and download it downloads it to the cRIO but everytime i restart the robot it deletes itself so i have come to the conclusion that i downloaded it to the RAM and thus is has a phyiscal memory dump every shutdown. can anyone fix this?
Unread 11-05-2010, 16:00
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: downloading issue
You are using Windriver correct? And using the FIRST->Download button?
Also, how do you know it is deleting your code?
Does it say "No Code"? If so, that could be a different error such as undefined symbols, AKA- A problem in your code.
Unread 11-05-2010, 16:06
FRC #2904
i tried first download but it had the same effect.
when i rebooted i went into the driver station and it said "no code".
Unread 11-05-2010, 16:14
FRC #2904
oh and i was using the simple robot template and i didnt do anything to it.
Unread 11-05-2010, 18:04
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Did you set up the FIRST downloader to work with your project? Go to Window->Preferences (I think) and click on FIRST downloader. Enter your team number and locate the .out file for your project.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 14-05-2010, 15:22
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Have you tried FTP to it? (10.xx.yy.1 Username:FRC Password:FRC, where xx is the first two digits of your team # and yy is the last two digits.)
It is supposed to be under the "ni-rt" directory and called "FRC_UserProgram.out".
How do you do that? RAM (literally) can only be accessed by the computer itself...
-Masoug
JabbaScript
Unread 14-05-2010, 20:38
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
It's done with the Run/Debug (popcorn!) kernel task command in Windriver. WR sends it to the cRIO, which immediately loads it into memory, and runs it without saving it to a file.
Watchdog.Kill();
Downloading error dnrobotics11 C/C++ 2 02-02-2009 18:52
Downloading help Lyrix NI LabVIEW 1 22-01-2009 00:39
An Issue with downloading the Master Code. Neil [Coconuts] Programming 6 07-02-2008 14:03
Issue with downloading code to the 2007 RC thefro526 Programming 3 10-02-2007 17:26
downloading problems. Dylan Gramlich VEX 9 13-12-2006 13:03
