Go to Post Even worse, you could have a "Kiss the Paul" contest. I heard he squeals when you pick him up too. - AndyB [more]
Unread 25-05-2010, 20:39
ajd ajd is offline
FRC #3238
ajd will become famous soon enough
cRIO isolation pads?
We just received our new cRIO-FRC from NI, and it came with some adhesive-backed pads. They had holes in them that fit around some of the ports on the cRIO chassis (e.g. the two ethernet holes, the power connector, serial port, and indicator light). However, they only fit correctly around the ports when the pad is turned upside down, with the adhesive facing up around the chassis. How are these pads supposed to be used? What function do they serve?
Unread 25-05-2010, 21:11
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: cRIO isolation pads?
Do they look like these? http://www.andymark.biz/am-0590.html
Unread 25-05-2010, 21:16
Directions are posted by NI here:
How Do I Clean My cRIO-FRC and Install Protective Gaskets?
They keep metal dust and shards out of the cRIO electronics. Quite a lot pile up inside the chassis over a season mounted within a robot. Drilling, filing, gears grinding, metal rubbing, all produce debris that works it's way into the cRIO.
Those gaskets seal around the most obvious openings.
Unread 25-05-2010, 22:35
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Have there been any failures from this sort of thing?
-- Marshal Horn
Unread 25-05-2010, 23:24
ajd ajd is offline
FRC #3238
Aha! My coach and I both assumed that the gaskets were for the outside of the cRIO, this makes it clear that they are instead for the inside. Thanks for the help!
Unread 26-05-2010, 07:53
Yes. Not a large number, but it seems to be the primary issue that will blow the internal fuse. If you follow the directions and clean the cRIO, you can judge for yourself. In my best Billy Mays voice -- Just how much debris is in YOUR cRIO?
Greg McKaskle
Vibration Isolation Mounts Free Willy Pneumatics 10 19-02-2010 07:40
Balancing Pads ROFLcopter Rules/Strategy 5 15-02-2009 19:39
chassis isolation, contrary to UL1740? grambo Electrical 10 18-10-2008 20:18
Pressure Pads Deltafrog Rules/Strategy 6 09-01-2005 00:27
Knee Pads kjohnson Rules/Strategy 6 09-02-2004 22:05
