Go to Post well yeah, but we can dream, can't we? - Nuttyman54 [more]
Unread 27-05-2010, 23:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
What Would You Say From Past Robotics Experiences... (Procedural or Object-Oriented?)
That programming on a robot is more procedural than object oriented. I realize that I first had difficulty with programming a robot because I was so focused on OO. Sure I may not be 100% sure about the actual definitions of OO and Procedural, but I think I can say robot programming is highly procedural. Anyone disagree?
After reading Wiki, its definitely even driven
Unread 28-05-2010, 07:36
Jared Russell's Avatar
Taking a year (mostly) off
Re: What Would You Say From Past Robotics Experiences...
How procedural or OO the programming is on your robot is entirely up to the programmer. I have seen effective robot code done both ways.
Unread 28-05-2010, 07:41
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Our own system, which runs on a framework we're releasing sometime in the future, is extremely OO. I think that if we had tried to do a lot of the things we did in a procedural manner, it wouldn't have gone as well.
GSR Dean's List Finalist 2011
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
What would I say?
I would say that this is what is known as an ill-formed question. It both presents a false dichotomy, and focuses attention on the tail that wags the dog.
I'm going to shoot from the hip, and suggest that you should ask this "Are robot programmers (and the software tools available to them) more procedural than object oriented?"
While my suggested question might seem as interesting than the one you used. I think it is more on-target.
Blake
Unread 28-05-2010, 08:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The basis of OO programming is organizing the code before the coding begins. Robots are no different: if you start with an architecture that separates constants, utility functions and critical functions, it's easy to create an object-oriented robot codeset that is efficient. Additionally, tools like threads and timers may be folded into the architecture so that simultaneous tasks can run. Each function may be procedural, yet the management of the functions does not have to be.
GitHub
Unread 28-05-2010, 10:07
That's like asking "Do you walk to school, or bring your lunch?" Object Oriented and Procedural Programming are not on the same scale. You can have OO with or without PP, and you can have PP with or without OO.
There's not much support for Object Oriented Programming at the user level in LabVIEW, so a large number of teams this past year had neither OO nor PP.
Unread 28-05-2010, 10:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now I think I do both at the same time....
Unread 28-05-2010, 17:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: What Would You Say From Past Robotics Experiences... (Procedural or Object-Orient
Please make the title of the threads you start more clear.
Thanks.
--Madison--
...down at the Ozdust!
What Would You Say To The Newer Members Of CD - 2nd Edition JaneYoung General Forum 54 04-02-2016 19:43
What Do You Wish You Would Have Known Your Rookie Year? SlaminSwimster General Forum 77 16-12-2008 12:13
what what would you like to see in a team website? fimmel Website Design/Showcase 24 08-11-2006 08:32
What would you say to newer members of the CD community? Ken Leung General Forum 18 02-06-2006 12:05
What have you done in past years? Lora Knepper Chairman's Award 3 03-06-2001 18:23
