Mechanical going Electric
I am getting tired of CADding up chassis for robots, so I've decided to build my own over the summer. I've done a bit of research, and decided I want to start off with this chassis: http://www3.towerhobbies.com/cgi-bin...&I=LXGZ87&P=FR
I'm not sure what it will take to make it remote controlled though. I know I need a dual motor gearbox (same supplier) to make the left and right treads run independently. What else do I need to do to make this into a r/c? |
Re: Mechanical going Electric
There are so many different ways you could build this into an RC platform, it all depends on your resources. If you have enough money for a vex kit with the programming tool (and you want autonomous), I would definitely go with that though.
Searching the rest of the internet for info on how to do stuff like this has often ended well for me, and I would suggest it if you haven't been there already. There are DIY people everywhere. EDIT: Forgot to mention, if you have an old rc vehicle, and you are willing to let it die, figure out how it works and convert its controls to suit your purpose (nondestructive disassembly is important here, I made that mistake a while ago )Last edited by ,4lex S. : 14-06-2010 at 18:10. Reason: Can't spell at all... |
I don't know much myself, and I'm sure people here on CD can help you, but at this point it would probably be easiest to enlist a partner on your project (probably from your team, or any electrical person willing to help). Because you don't really know what you're doing, that'd probably be the best choice. Also, that way you could not only make sure it's done right, but also learn what's being done and why. IMO, anyway.
http://www.robotshop.com/New-arrival...basic-kit.html Any other things I should get to go along with this to start out? |
Edit:
To make that tank unit into something RC you'll need: 2 motors and the 2-motor transmission like you said Battery pack(s) and charger 2 motor controllers A radio system, maybe 3 or 4 channels so you could add functionality to the chassis other than driving. Pay attention to the actual control input on the remote and make sure it's how you want to control tank-steer. Misc wires/cables/switches/velcro When it's all said and done you'll have put a reasonable bit of $$ into a $15 chassis, you may want to think about getting a larger, more capable chassis. A buddy of mine, AndyA on CD, and I used to make IFI-powered RC cars. A victor 883 can handle 24 volts IIRC and can be controlled with a regular hobby RC remote. We coupled a victor 883 with two high-capacity 7.2V RC racing packs wired in series and used those to power a 14.4V companion drill motor. Buying RC stuff second hand from ebay kept costs low. The wiring is very similar to a FIRST robot because you have a PWM signal running to a motor controller that has batteries on one side and a motor on the other, there's just one motor instead of 4, 6, or whatever. It was a very fun hobby and you'll learn a lot, like how a Victor can handle flat-out power for 20-30 minutes without a fan and be fine. Just a thought. Last edited by JamesCH95 : 15-06-2010 at 11:27. |
#8
As a warning, do NOT buy just the module thinking you can solder it yourself. They are .1" spaced solder pads and are a real pain to solder to. If you don't want to program I would see if you could borrow one of the old IFI systems from your team or buy a Vex kit. Personally, I would buy a Vex kit. (Of course, I am LOOKING for an excuse to buy one so I can try to convince KU to put together a team) |
#9
All it takes to solder small things is good eyesight (or a magnifying glass, which is helpful for SMT parts) and a steady hand. The latter takes some practice at clearing your mind to reduce shaking, but once you've done it enough you can chug a cup of coffee still be able to solder parts. A good way to practice soldering is grab some old electronics; 1990s or earlier vintage is recommended as many of these still used through-hole (.1" spacing) parts. Do NOT disassemble CRT monitors or CRT television sets, as they contain very high voltage components that retain deadly charges for years. I'd recommend VCRs, as they also contain a few motors to play with. But just desolder and resolder parts on the circuit boards. To desolder parts you'll need a solder wick or solder sucker (or just heat the solder up and slam the board on the table and momentum will cause the solder to fly out ). |
#10
Change of plans. I'm going to build my own robot completely from scratch. I was planning on using the following items:
http://www.robotmarketplace.com/products/IL-TKT1.html http://www.robotmarketplace.com/products/IL-GMS100.html I will also be creating a chassis myself to mount these. Beyond this, I don't know what I need. Having it R/C would be really cool, and I'm open to programming necessary. As far as only autonomous, I'm not sure that'd be a good to take on that much at once. I am open to exploring it later on though. Any guidance on specific parts or general advice would be greatly appreciated. |
#12
Your team is old enough that you might have one, or both, of the edu-bot RCs lying around. These are good bases for smaller robot projects.
IMHO you should go with a drive train and chassis that's a little more substantial, heck for a few bucks more you can get noticeably more powerful motors: http://www.robotmarketplace.com/products/0-72001.html As for what you'll need: A speed controller or relay for every motor A robot controller or R/C receiver An R/C transmitter A battery pack Fuses, switches, wires, ect |
| FIRSTcast 2.9 - Electric Boogaloo! | Joe Matt | General Forum | 5 | 16-03-2007 10:37 |
| Electric Bicycle | RudimentaryPeni | Chit-Chat | 6 | 05-10-2006 14:24 |
| Electric Solenoids | BerserkerSpyke | Rules/Strategy | 3 | 01-02-2006 17:36 |
| Electric Solenoid | ThomasP | Motors | 5 | 10-01-2006 16:47 |
| Gas or Electric?? | Clark Gilbert | Chit-Chat | 14 | 11-08-2001 12:16 |
