Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 09-07-2010, 22:09
Noob Ardie Noob Ardie is offline
Noob Ardie is an unknown quantity at this point
labview and Arduino combo
Hi people,
Is it possible to control 6 motors independently and getting some sensor readings all using an arduino mega and labview. Does each of the motor need its own motor controller or can the arduino + labview combo program one.
Really appreciate the help and thanks in advance for reading.
Noob Ardie
Unread 11-07-2010, 10:53
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: labview and Arduino combo
See this thread or this webpage for info on interfacing LabVIEW with Arduinos.
In terms of controlling motors, it depends on what type and size of motors you have. Small (what I tend to call) "hobby motors" you could probably control with just a transistor controlled by one of the Arduino's digital output pins. If you want to use motors much bigger than that, you'd probably going to need to get an actual motor controller. The Arduino should be able to control all six motors, but you'll need 6 motor controllers to do the current switching (although motor controllers packaged in 2s are commonly available). Many motor controllers (including the Victors and Jaguars from FIRST) are PPM/PWM controlled, so check out the Arduino's servo libraries.
--Ryan
FRC 766, 2015-, Mentor
Unread 11-07-2010, 12:07
Thanks Ryan for the response. that was nice of you, with the weekend and all.
I would be trying out the arduino on a mock up soon and will update on the results..
Controlling Arduino through Labview eitang NI LabVIEW 10 06-12-2010 01:20
CRIO ARDUINO INTERFACE Robototes2412 Java 25 03-07-2010 08:25
combo encoder and chain tensioner SteveJanesch Electrical 8 17-12-2009 16:55
Using an Arduino as a robot controller (2010 and beyond?) Leav Control System 14 13-02-2009 22:35
Vex/Arduino Serial Port Help weinbergmath Programming 2 30-05-2008 20:43
