Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 02-08-2010, 16:08
siaohuang siaohuang is offline
siaohuang is an unknown quantity at this point
Error - Invalid 18f8520 header file! Vex Robotics Kit
First of all I'm a newbie at the Vex Robotics Kit here are the things I've already done
I've successfully installed Mplab v8.10 and C18 compiler v3.35 , I went through the user guides and successfully build the first program, the "Hello World!!" program,so I think my C compiler is working
I downloaded the Vex Starter Code and extracted to a file called "VexCode" I placed it under the directory C:\mcc18\VexCode I opened VexUserCode.mcw (work space) and imported VexUserCode.mcp (project)
I set the Project--> Build options ---> Project and set the Include search path to C:\mcc18\h and C:\mcc18\VexCode
and the Library search path to C:\mcc18\lib and C:\mcc18\VexCode
and Linker script search path to C:\mcc18\VexCode the Linker script is in the VexCode folder 18f8520user.lkr
Then Build all in the output window it shows
Debug build of project `C:\mcc18\VexCode\VexUserCode.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Tue Aug 03 03:19:32 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\mcc18\VexCode\VexUserCode.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\VexCode" -I"C:\mcc18\h" "user_routines_fast.c" -fo="user_routines_fast.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\mcc18\VexCode\ifi_picdefs.h:1289:Error [1099] *** Error - Invalid 18f8520 header file!
Halting build on first failure as requested.
Debug build of project `C:\mcc18\VexCode\VexUserCode.mcp' failed.
Can anyone solve this? Thank you for you time!!
Unread 02-08-2010, 16:33
Re: Error - Invalid 18f8520 header file! Vex Robotics Kit
Did you install MPLAB/C18 from the VEX CD or did you also download any updates from online?
That error seems to indicate that the ifi_picdefs.h file is being inserted twice. It has a check at the beginning to prevent that though...
Unread 02-08-2010, 17:06
Thanks for your reply I downloaded my Mplab and C18 from
http://www.microchip.com/stellent/id...en023073&part=
I also saw a forum
http://www.chiefdelphi.com/forums/sh...ad.php?t=31255
It seems that we have similar problems in the forum it mentioned something about the macro setting and I also tried adding "_FRC_BOARD" to the macro definitions and it still didn't work
Thanks for reading.
Unread 02-08-2010, 17:21
Thank for your reply I downloaded my Mplab v8.10 and C18 v3.35 from
and i saw the thread that mentioned the macro defintions so i ADDED "_FRC_BOARD" to my macro definitions and it didn't work as well
thanks for replying it means a lot to me!!
Unread 02-08-2010, 18:38
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
#define _VEX_BOARD
is what you want for the VEX board.
Let me recommend that you visit the: WPI Lib for VEX/FRC site and grab that library. It will make your programming about 1000 times easier. There are full instructions on how to make it work with MPLabs.
The Microchip compiler / linker is very fussy when it comes to path names, etc. in the setup.
Keep us posted on how you make out.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 03-08-2010, 12:09
Thanks for all you guys' help!! I got it to work I try downloading older versions of Mplab v7.60 and C18 v2.40 and I downloaded Elevation - Appendix D (Programming Guide) from http://www.vexforum.com/wiki/index.php/Elevation
when you extract the file it willgive you the VexCode file and deleting the old library files and adding a new one Vex_2008_library.lib from the MPLAB-Autonomous-Code Rev2 - Vex Code
now when I build the mpw file it gives me
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "user_routines_fast.c" -fo="user_routines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "printf_lib.c" -fo="printf_lib.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 /i"C:\mcc18\h" "main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\VexCode\18f8520user.lkr" "C:\VexCode\user_routines_fast.o" "C:\VexCode\ifi_startup.o" "C:\VexCode\printf_lib.o" "C:\VexCode\user_routines.o" "C:\VexCode\ifi_utilities.o" "C:\VexCode\main.o" "C:\VexCode\Vex_2008_library.lib" /o"VexUserCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Errors : 0
MP2COD 3.90, COFF to COD File Converter
Errors : 0
MP2HEX 3.90, COFF to HEX File Converter
Errors : 0
Loaded C:\VexCode\VexUserCode.cof.
BUILD SUCCEEDED: Wed Aug 04 00:08:48 2010
once again thanks for all your help!! Happy programming!
Unread 03-08-2010, 14:00
Great!
This error usually seems to be a mismatch between the versions of the C18 software, the Vex libraries, and the program.
Unread 02-08-2010, 18:54
Shouldn't it turn out as pictures?
Header File Missing BloodSoakedTear Programming 1 26-02-2006 16:54
Error in header file p18f8520.h !!! RbtGal1351 Programming 3 17-01-2005 16:03
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Header File error message Mike Yan Programming 2 09-02-2004 11:31
Needing A header file jweric Programming 19 23-01-2004 10:25
