Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-08-2010, 20:45
Techwiz's Avatar
Techwiz Techwiz is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
Techwiz will become famous soon enough
What am I doing wrong? grrrrrrr
Hello All...
So my team(2648) just bought a new black Jaguar, and the required serial to rj12 connector.
I hooked it up to my computer, and ran the BDC-COMM program, it says "Status: Connected"
I downloaded the firmware, qs-bdc25.bin and it seemed successfull.
then I preceded to try to set the motor voltage, and the display at the bottom of the GUI says Vout 11.95. But when i connect a meter to the terminals, i get az reading of 0. Also after connecting a motor, changing the voltage again, the motor does not move.
any ideas?
Did i do something wrong.
Is tehre any documentation otner than that of whats on the luminaryMicro site?
Thanks,
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 04-08-2010, 20:59
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: What am I doing wrong? grrrrrrr
qs-bdc24.bin isn't the FRC CAN firmware. You should be loading BlackJaguar-91.bin from this file (accept the license agreement at the bottom to download)
Also make sure you have this version of BDC-COMM
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 04-08-2010, 22:46
Techwiz's Avatar
Blake B
AKA: Blake
So yea,
I got that version of the firmware, updated its firmware.
rebooted the system
set the voltage slider top max, and again red blinky light.
any other ideas?
One thing i did observe:
i got this error message once:
"unable to contact the boot loader!"
Blake
Unread 05-08-2010, 10:08
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Did you make the cable yourself? If so, did you terminate it correctly? You need to make a terminator to plug into the last unused rj12 port on the jaguar. More information can be found in the Getting started guide.
Unread 05-08-2010, 12:04
AKA: Ian Thompson
You're seeing a red blinking light when setting the motor to forward? That means the jaguar is detecting a fault somewhere. Make sure Vbus is a reasonable number, and that Limit doesn't have a F or R in it. If there is an F or R in Limit, double-check the jumpers on the jag
Unread 05-08-2010, 19:40
Techwiz's Avatar
Blake B
AKA: Blake
Ah that was it.
I rotated both of the jumpers 90 degrees, the F and R went away and I was able to control the motor.
Thanks for your help,
Blake
Lego Mindstorms: What went wrong? Cyberguy34000 Lego Mindstorm Discussion 27 04-12-2012 08:45
What is your team doing thomasnat1 Chairman's Award 8 20-01-2009 15:45
What is wrong with this part Adam Y. Inventor 11 10-04-2008 20:36
okay what the heck is wrong with me Zeinin Chit-Chat 8 16-01-2002 13:09
