pic: Enigma Wheel
Re: pic: Enigma Wheel
Wow... It's been awhile since I've been on here... Finally something I'm semi qualified to speak about. Semi.
First off, the CAD looks very nice. And the wheel is a decent design, except for the loop on the end of the spokes. It is very likely to snap there. And the part after it contacts the wheel is just adding weight. Any chance of a different view angle? (If you have it on a picasa or photobucket, something like that?) How wide is the wheel? What's the width of the spokes? The depth? Whats the bore diameter? -Rion |
I dunno about their actual usage plan for the wheel is for, but I'm guessing that it'd be for more show then function.
i don't think the spokes will break, if the center bore is .5 in then those spokes are pretty thick. if you are planning to use these in a 6wd robot then i think it should be fine, as longs as there are no bumps in next years game.
Looks like fun!
If you have an experienced mechanical mentor available, ask her to show you how to do a "Finite Element Analysis" or to simulate what types of stresses will develop when you load it. This design should show some very interesting and informing results. |
Then... create a light, snap-on decorative hubcap that fits onto that wheel and adds only trivial weight to the completed assembly. The hubcap's wow-factor is limited only by your imagination (and the audiences' ability to appreciate fine art ). |
#7
I'll get some other views of it. As I said my computer wasn't cooperating with me. Quote:
Edit: Wheel is 1.5in deep, 6in wide Spokes are .5in deep, .25in wide Any other measurements you would like? Last edited by kgzak : 08-08-2010 at 16:50. Reason: Computer was Cooperating |
#8
I think it would be more reasonable, if you wanted the question marks, to make fairly large spokes and use the question mark shape as a lightening pattern.
#9
Another nitpick: You're going to need to cut out a groove for the bearings in your wheel.
#11
Are you running Inventor? I haven't been able to get a hold of Solidworks or Inventor recently so I can't remember which one has the 3 axis in the bottom that looks like that. New picture edit: I don't know if the spokes have enough contact with the wheel. I also think you may be ale to pull weight out of the hub there. Last edited by Rion Atkinson : 08-08-2010 at 20:40. |
#12
I'm with Blake on this one. There are options to make it very aesthetically pleasing using a hub cab, including annodizing the wheel and the decoration different colors. Even doing this to an AM Plaction wheel and no plate annodization could be 'pretty'.
Of course the drive train needs to be designed such that the wheels can be seen to begin with, otherwise wheel aesthetics are for naught. In 2008 & 2009 aesthetic wheel design proved futile due to bumper rules, which is another thing to keep in mind during build season. |
| Enigma | thinker | Chit-Chat | 0 | 28-04-2009 09:45 |
| pic: Team 2075 Enigma 2009 Robot | Enigma's puzzle | Extra Discussion | 1 | 20-02-2009 11:29 |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| Thank You Enigma Team 356 | BBFIRSTCHICK | Thanks and/or Congrats | 3 | 31-03-2003 19:06 |
