javascript data type ?
Hi ,
I am sending a function an array of values which contain '09' , '15','20' ,...etc everything is working fine except when I have to do something with '09' it seems to truncate off the zero at the begining and pass to the function a 9 instead of a 09 What I want to know is how do I make the function interpert the value as 09 it seems to be converting the parameter to a number instead of the string value '09' array[0] = '09'; array[1] = '15'; ..etc Thanks for any help |
Re: javascript data type ?
sithum,
can you give more detail about what you're trying to do with the values? I tried your example: Code:
<html> <body> <script type="text/javascript"> var arr = new Array(); arr[0] = '09'; arr[1] = '15'; arr[2] = '20'; for(var i in arr) document.write(arr[i]+'<br/>'); </script> </body> </html> Code:
09 15 20 |
| p1_sw_aux data type | personfromhell | Programming | 8 | 02-02-2008 18:40 |
| printing FLOAT data type on the terminal window | razer | Programming | 14 | 05-02-2007 08:55 |
| javascript ate my cereal! | steveg | IT / Communications | 2 | 29-03-2004 01:10 |
| Field Location of Type-0 and Type-1 IR Signals | Travis Hoffman | General Forum | 3 | 27-02-2004 07:58 |
