Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 17-08-2010, 21:01
pfreivald's Avatar
AKA: Patrick Freivald
Pneumatic Dump Valve for T-Shirt Launcher
Can anyone recommend a pneumatic dump valve -- preferably solenoid controlled -- for a T-shirt launcher? We're looking for lots of air flow and rated for 100-ish PSI.
Thanks!
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 18-08-2010, 10:31
Josh Adkins's Avatar
Josh Adkins Josh Adkins is offline
Josh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud of
Re: Pneumatic Dump Valve for T-Shirt Launcher
Our team modified a sprinkler valve. Hardware stores normally have a good selection of these valves
http://www.instructables.com/id/Golf...rinkler-Valve/
Instead of using a blowoff valve to release the air holding down the diaphram we used a KoP solenoid valve. For about $25 you will have a high flow (about .6in^2) remotely operated valve.
Unread 18-08-2010, 11:01
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Our team also used a sprinkler valve, but we hooked it up to a relay instead of a solenoid.
Our local hardware store had plenty of 12v sprinkler valves for about $20. Just make sure that you get a 12v valve, as a large number of the valves operate on 24v.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 18-08-2010, 11:21
If I understand correctly you used the solenoid already attached to the sprinkler valve rather than modifying it?
I think the only difference between the two methods is the time it takes to release the valve. I've read the modified sprinkler valve releases up to 10x faster, but I've never actually tested one without modifying it.
You could always test the sprinler valve out of the box, and, if your not getting the results you want, go ahead and modify it.
Unread 18-08-2010, 18:51
AKA: Bryan
Yes, sorry, wasn't thinking this morning.
We haven't had any problems with the speed at which it releases, but experience has told us that our system is relatively inefficient. We have considered improving it, but for our purposes what we have works fine. It takes a good while to get the 5gal tank back up to full after we launch a T-shirt, but we usually can only shoot off about 2-3 t-shirts at a time anyway. The full 5gal tank can shoot one to the back of the stands, one to the middle, and one up front consecutively with no problems.
Unread 18-08-2010, 22:57
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
We've had great success with this valve which is engineering for compressed air. A spike relay controlls this 12VDC valve perfectly. Dump is instantanously.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 19-08-2010, 23:42
pfreivald's Avatar
Thanks, all! A mentor brought in a valve -- no idea what it was originally used for, but it's steel and it's robust as heck and with it we shot a T-shirt 82 feet today. (That's more than enough distance given the venues in which we will be firing, and it will likely improve as we tweak things anyway.)
Team 1551
I write books, too!
Unread 20-08-2010, 09:54
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Be sure to post pictures and video!
Hi!
pic: Team 1716 T-shirt Launcher McGurky Extra Discussion 12 11-01-2011 15:08
T-shirt launcher: Help? archer003 Technical Discussion 0 07-03-2010 16:49
T-shirt collection for NJ Regional - (T-Shirt Launcher) Team 2016 General Forum 0 17-02-2010 12:33
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
