Go to Post Joe is a great sport and this was a good moral booster after a grueling weekend. How many opportunities do you get to play William Tell with a Regional WFA Winner? :) - The Lucas [more]
Unread 20-09-2010, 12:16
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
ROS in FIRST ?
I know the Robot Operating System (ROS) topic has been discussed briefly on the forums however the Robotics world is always changing.
Has anyone considered getting the cRio to run ROS client ?
After seeing Lego NXT achieve the ROS hurdle, FRC is definitely a possibility.
http://www.willowgarage.com/blog/201...i-pr2-lego-nxt
If FRC can make the jump, ROS will provide robots with
  • Multi-robot autonomous routines
  • Enhanced data logging
  • sophisticated path planning and obstacle avoidance
Reply to this thread or PM if your interested in starting a software push for ROS on FRC.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 21-09-2010, 20:16
Re: ROS in FIRST ?
The NXT is described as running standard LEGO firmware, so the ROS tools seem to be using it as a drone. The host PC does all the thinking, and via the direct commands that are built into the NXT protocol, ROS directs a motor to turn on or off, reads a sensor, etc. Microsoft Robotics Studio also had NXT support with its tools, though I believe it only supported one model whereas the ROS can load more complex LDD models, and presumably use them more effectively in its steering model, physics modeling, etc.
As for the ROS running on the cRIO, of course it is technically possible. NI Robotics folks have looked into it several times to determine how difficult different levels of ROS support would be and what they would bring to the table. Integration of the LV robotics libraries with ROS would allow for even more tools, but to this point, it hasn't justified the effort.
Greg McKaskle
Unread 18-01-2014, 13:06
Dr.Bot
Posts: n/a
Re: ROS in FIRST ?
I Just saw this:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210716
Apparently you can use ROS and a Crio, but I don't know if it is practical to get it working during build season. It is pretty easy to run ROS on a Beaglebone or Pandaboard (any Unbuntu system) - whether it can work with the Driver Station is another matter.
Unread 24-06-2014, 15:38
luc.bettaieb's Avatar
luc.bettaieb luc.bettaieb is offline
AKA: Luc Bettaieb
FRC #1329 (Roborebels)
luc.bettaieb is an unknown quantity at this point
Re: ROS in FIRST ?
As a FRC Alum and an undergrad who uses ROS in robotics research, I fully support this idea.
ROS would be a tremendous thing to implement for FRC since it's rapidly becoming / already is the standard for research robotics.
Unread 04-07-2014, 18:04
dmaki dmaki is offline
First VISTA
AKA: Dustin Maki
dmaki is a jewel in the roughdmaki is a jewel in the roughdmaki is a jewel in the roughdmaki is a jewel in the rough
Re: ROS in FIRST ?
Old thread, but here is something regarding ROS on the new 2015 control system.
from https://decibel.ni.com/content/docs/DOC-30419
NI roboRIO Details and Specifications
new comment by DAQjr View all comments on this document
dmaki wrote:
What Linux Distro will be running on the RoboRIO? What are the real time extensions?
I would like to see if I can get it to run ROS. ROS.org
Do you think that would be a technical possibility?
I was recently asked for my input on potential rule changes. If a robot could potentially run ROS, a rule may need to be made to allow it or disallow it.
Dustin Maki
Hueter added links to the FAQ about the OS and what real-time extensions are. The distribution is called NI Linux Real-Time. It is built with Open Embedded.
I see no reason that ROS would not build for the roboRIO with no issues. Google says: http://wiki.ros.org/ROS/CrossCompiling
I don't think there's a reason why ROS would require a rule change.
This Weekend! - Delaware FIRST Vex Challenge & First State FIRST LEGO League Tourney Mr MOE General Forum 4 28-01-2007 07:59
INBOX: **FIRST EMAIL**/Call for 2005 FIRST Robotics Confe... Billfred FIRST E-Mail Blast Archive 0 16-12-2004 18:16
**FIRST EMAIL**/FIRST Annual Fund Message from James R. Utaski, FIRST Board of Direct miketwalker FIRST E-Mail Blast Archive 0 27-05-2004 11:25
**FIRST EMAIL**/2004 FIRST LEGO League Registration Open Now! miketwalker FIRST E-Mail Blast Archive 0 06-05-2004 17:14
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
