Go to Post I think the GDC should force us to use steam engines, but the electrically-inclined folks on my team might stop whining if they're given more to work with. - Madison [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 12-10-2010, 22:23
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Smile [OCCRA]: OCCRA VEX Cortex Test Program
OCCRA,
Here is a simple VEX, Cortex EasyC test program I created to demonstrate use of the VEXnet competition template.
1) After downloading any program including this one, cycle (turn off then on) the power to the Cortex controller.
2) This program outputs a line of text to the graphic display inside of EasyC V4. Graphic display is different than terminal display.
3) When VEXnet is disabled, the graphic display on line 2 displays for 1 -second the words OCCRA TEST PROGRAM - Initialized
4) When VEXnet is enabled in the autonomous mode from the disabled mode, the words OCCRA TEST PROGRAM - Autonomous on line 4 displays for 1-second and continues to display if left in this mode.
5) Switching to Operator control mode, the words OCCRA TEST PROGRAM - Initialized will flash in line 2 for 1 second, then the words OCCRA TEST PROGRAM - Operator Control on line 6 displays for 1 second and continues to display if left in this mode.
6) Switching to disable mode clears the graphic display and flashes the words OCCRA TEST PROGRAM - Initialized for 1 second?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
[OCCRA]: Assembly on the cortex Fireball9199 OCCRA Programming 3 04-10-2010 21:35
[OCCRA]: cortex power supply off/on bernieseaholm OCCRA Q&A 1 23-09-2010 08:32
[OCCRA]: OCCRA 2009 VEXnet Test Program marccenter OCCRA Programming 2 01-11-2009 21:46
[OCCRA]: OCCRA 2008 Drive Straight Program w/PI Control marccenter OCCRA Programming 2 01-05-2009 16:14
