Go to Post Don't bring a distraction to the field. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 20-10-2010, 12:11
bernieseaholm bernieseaholm is offline
FRC #2960 (automation nation)
bernieseaholm is an unknown quantity at this point
[OCCRA]: spikes and cortex
Our team is trying to connect two spike relays to control pneumatic valving. we are unsure as to where to connect the spikes on the cortex and are unable to find documents that direct us. Where do the spikes connect on the cortex? It is our intent to use the secondary joystick for control.
Unread 20-10-2010, 20:50
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: spikes and cortex
Question: Our team is trying to connect two spike relays to control pneumatic valving. we are unsure as to where to connect the spikes on the cortex and are unable to find documents that direct us. Where do the spikes connect on the cortex? It is our intent to use the secondary joystick for control.
Answer:
I do know you will not use the Motor port.....
I think you plug the PWM into the analog port as you would a simple limit switch (you will need to adjust your software in EasyC 4. All other power connections for the valve wires (red/Black) are the same - refer to the pneumatics manual.
I will contact IFI tonight and double check this answer and re-post as soon as I get an answer.
Read the post in the Q & A section as another team has an answer.... however I cannot verify the answer to be accurate.
Mike Martus
Unread 26-10-2010, 18:23
Here is a link to the answer from IFI.
http://www.vexforum.com/showthread.php?t=374
Mike Martus
[OCCRA]: OCCRA VEX Cortex Test Program marccenter OCCRA Programming 0 12-10-2010 22:23
[OCCRA]: Assembly on the cortex Fireball9199 OCCRA Programming 3 04-10-2010 21:35
[OCCRA]: cortex power supply off/on bernieseaholm OCCRA Q&A 1 23-09-2010 08:32
[OCCRA]: Keyangs on Spikes apalrd OCCRA 9 19-11-2009 09:36
