Go to Post You don't need to prototype everything, just the stuff you want to work. - JVN [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 27-10-2010, 18:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
[OCCRA]: Partner controller not linking up
Somebody asked a question about partner link-up in the Q&A forum, and only Mike Martus can reply there.
It seems as though your batteries are dead on the partner. Like dead-dead, should change now dead, will not work dead. You should change them before every competition, and again if they die.
There is no configuration for the partner. Connect and go.
Kettering Motorsports
Unread 28-10-2010, 14:48
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Re: [OCCRA]: Partner controller not linking up
1) the batteries are not dead. We have replacedthem several times and it does not look like that kind of a problem.
We may have configured the controller by plugging it into the cortex but if that were true, then it would never link up. This is an intermitent problem. 90% of the time, after turning on the controllers they fail to link to each other but the other 10% of the time, they will linkup no problem and have the proper lightcolors.
WE ARE USING DEFAULT CODE!!!!
Therefore, no firmware should be needed on either controller.
If we do have the partner linked to the cortex, then we need to know how to undo that.
Unread 29-10-2010, 18:02
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
We worked on this at the comp.
Step 1 is to make sure you have a green power light. If it will not link you must reconfigure the control. Follow the steps in the docs. On rare occasions you will need to use a paperclip and reconfigure. Then redownload the firmware yes again. Relink and try. If only partner controller this will work.
Let me know.
Mike Martus
[OCCRA]: Partner Controller not linking whatabouteve OCCRA Q&A 1 27-10-2010 19:56
[OCCRA]: Linking Vex Transmitter and Microcontroller bernieseaholm OCCRA Programming 6 14-11-2009 18:17
[OCCRA]: Major VEX Controller Problem surferacf OCCRA Programming 1 29-10-2008 15:01
[OCCRA]: Robot Controller (electrical box) problem Kettering OCCRA Q&A 1 20-10-2008 09:03
Linking Errors: "section '????' can not fit the section. ..." Astronouth7303 Programming 3 16-01-2005 21:36
