Linksys Router (WRT610N V1) Connection Problem
My linksys router Model WRT610N V1 is connected into the modem, and when I try to use the FRC issued laptop and connect to the router. It does not connect so I reset the router, to somehow, fix the problem. Nothing seems to be working, and I was hoping if anyone could provide tips or help to solve the issue.
Re: Linksys Router (WRT610N V1) Connection Problem
Classmate ethernet port should be connected to one of the router's ethernet ports with an ethernet cable. Check? Classmate IP address 10.xx.yy.5. Check? Router IP address is 10.xx.yy.4. Check? Open a browser on the Classmate and type 10.xx.yy.4 into the address box and you should see the router's setup screen. Check? Follow the instructions in this document and tell us at which step the problems start. Last edited by Ether : 10-11-2010 at 15:19. |
When you say "the modem" what device are you referring to?
I connected the router to the main modem, which is plugged into several other computers. Classmate ethernet port should be connected to one of the router's ethernet ports with an ethernet cable. Check? i dont understand what you mean by this Classmate IP address 10.xx.yy.5. Check? i typed 10.6.40.5. but nothing showed up Router IP address is 10.xx.yy.4. Check? same thing for the classmate IP address Open a browser on the Classmate and type 10.xx.yy.4 into the address box and you should see the router's setup screen. Check? Follow the instructions in this document and tell us at which step the problems start. |
You've identified the router as the WRT610N, which is fine. That's what came in the Kit of Parts. But we don't know what "the main modem" is. There shouldn't be a modem anywhere in what you are doing. Help us to help you by describing it in more detail than "the modem". Quote:
Do you know what the Classmate is? Do you know what an ethernet port is? Do you know what "connected to" means? Do you know what the router is? Do you know what an ethernet cable is? Everything you need to do is spelled out in the Getting Started guide. |
I have the same problem as RoboElite640. the only way we can move the robot is by plugging the laptop directly into cRIO by using another ethernet cable...
You have a modem too?
Seriously, RoboElite640's main problem at the moment appears to be insufficient experience with network components and connections in general. We can work through it, if we can get good enough answers to specific questions. Quote:
The solution is simply to disable security on the WGA. Connect a cable from it directly to the router, use a web browser to log in to its configuration page at http://10.18.65.1/ (those middle two octets are specific to your team), and set the security to none. |
#7
i cannot access the configuration page at all though... To answer your first question, it has worked a few times after the competition, however, after that, it has not wirelessly worked at all. I've finally managed to get the router working just yesterday, the bridge is still our only problem...
#8
Team 358 has a great website....try looking at the Network Troubleshooting document....it is excellent!
http://www.team358.org/files/program...olSystem2009-/ |
#9
Then you need to make sure the WGA is reset (use a paperclip to push the button behind the hole in the back) and follow the instructions in the Getting Started guide for setting it up from an out-of-the-box condition.
#10
Okay... but what exactly does that mean? (You must forgive me, I am still very new to this...)
#11
Open Chapter 2 at this link:
http://www.usfirst.org/roboticsprogr....aspx?id=10934 |
#12
There's also an easily-remembered alias:
http://www.usfirst.org/frccontrolsystem There are links from that page to pretty much everything you need to know. Chapter 2 in particular has sections containing step-by-step instructions for setting up each of the components. |
#13
#14
Thank you eerybody! I will work on all the methods later on... But I may get back on here Mondayfor more help if we are still not successful. Again, Thank you!
#15
You say your connecting to a modem, why?
| going back to Linksys wireless router | ahudson | Programming | 4 | 12-04-2010 17:20 |
| Using a router other than WRT610N | mgurgol | General Forum | 2 | 01-05-2009 16:50 |
| Help for the Cisco linksys router? | star_lancer | Technical Discussion | 2 | 31-01-2009 14:34 |
| Problem Setting Up Router | lingomaniac88 | FRC Control System | 2 | 14-01-2009 17:33 |
| Linksys Router Help | mtaman02 | Chit-Chat | 10 | 18-03-2004 01:04 |
