Go to Post We started FIRST to achieve a common goal and not only will we leave with more knowledge and wisdom, we will leave as friends and thats what really counts if you ask me. :cool: - Hick18 [more]
Unread 15-11-2010, 08:35
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
pic: Whoops! Too much torque
Unread 15-11-2010, 08:36
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: pic: Whoops! Too much torque
How did this happen? Too much cowbell?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 15-11-2010, 09:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think by cowbell, we mean what was the motor setup + gear ratio into this wheel? Also, how did the wheel stall?
GitHub
Unread 15-11-2010, 09:36
Chris is me's Avatar
AKA: Pinecone
The outer rims of the wheel seem like a really odd way for this wheel to shear. Wouldn't the bolt holes loosen, the sprocket bend, etc. before the outer part of the wheel broke? How does that relieve the stress?
Unread 15-11-2010, 10:51
Brandon Holley's Avatar
Pretty interesting failure. Definitely not typical from what I've seen out of the kit wheels in the past.
Still looks like it was due to the robot being pushed sideways in some manner.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 15-11-2010, 13:37
Racer26 Racer26 is offline
Sure looks like a side-loading failure to me. A rotational-loading failure would more likely manifest itself in shattering spokes, or breaking the holes in the hub.
Unread 15-11-2010, 13:44
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Team RUSH had a couple wheels go like that during the past season, those bumps were pretty rough, but we did add reinforcements to them by cutting pieces of what I believe was 1/16" aluminum and placing them between each set of spokes.
I don't fully understand what you mean by side-loading, so I'm not sure if that's the same as this, but I think the general belief is that our failures were due to the forces of impact on the wheels when they hit the ground.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 15-11-2010, 13:48
A force parallel to the wheel's axis I presume.
Unread 15-11-2010, 13:54
AKA: Foxy
That's what I assumed, I was just thinking that an impact force would be more likely to have this effect on the wheel, since it reflects what we saw happen in our own wheels this year.
Unread 15-11-2010, 13:59
"load" can include impact loads.
You get hit hard in the side, the impact creates a momentary side load (especially if the bottom of the wheel is against the bump or the goal ramp)
Unread 15-11-2010, 14:06
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Neat picture. As others say, my guess is not torque but a thump coming down of a ramp etc.
I will add for fun--possible plastic "creep". If that robot has been strapped in real tight to a shipping crate for what? 7 months now...that could cause some high stress points that now show up after standard use.
Troy
Unread 15-11-2010, 14:49
AKA: Pinecone
The odd thing about this is that 2200 had an omnidrectional robot that could not cross the bump. Perhaps their preseason prototype has enough power to break wheels by pushing?
Unread 15-11-2010, 15:03
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Correct:
Axle-Wheel-Load
_
---| | /___\
|_|
Woot ASCII Art
EDIT: It messes up my spacing.......
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 15-11-2010, 15:08
AKA: Pinecone
Correct:
Axle        Wheel     Load
                  _
-----------------| |    /_________\
                 |_|
Fixed art above.
Unread 16-11-2010, 21:07
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
1178 had something kind of like this happen at an off-season event (any Venturing Scouts might know about the Fall Fun Rally held in St. Louis, Boeing always asks us to come out to their events and show off a competition bot). After several hours of driving on asphalt, a scout drove the robot off the road, where one wheel got stuck. The scout proceeded to show the joystick all the way forward, and bent the sprocket and sheared off all the bolst holding the sprocket to the wheel. Needless to say, we were done driving that day.
pic: Too much Mech joeweber Extra Discussion 7 12-10-2009 11:48
Ball Capacity? How Much is Too Much? And Can You Use It For A Strategical Advantage? thefro526 Rules/Strategy 21 01-02-2009 02:56
Too much torque? Ctrl Alt Delete FIRST Tech Challenge 2 07-03-2006 01:55
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
