Go to Post If enough students "get it," the team will begin to. And if enough students "get it," the smart ones will seek out all the extra help they can get. That's how I found Chiefdelphi... - Joe G. [more]
Unread 15-11-2010, 17:29
tommy0019's Avatar
tommy0019 tommy0019 is offline
FRC #2957
tommy0019 is an unknown quantity at this point
servos problems
Our team is trying to use a servo to turn the camera. We want to make the servo turn to a certain position when a button is pressed. We were not sure what was wrong with our code so we tried moving the servo with the example servo program and the servo still did not respond. we tried another servo and that still did respond. Can anyone give us an explamation.
Unread 15-11-2010, 17:43
Re: servos problems
To make a servo work it requires a special jumper to provide raw power.
There are two pins right next to every PWM output.
Servos (and only servos) require a jumper on the pins beside the PWM output you are using to drive it.
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: servos problems
The servos require a jumper be placed on the digital sidecar next to the pwn output so that adequate voltage (6 v, I believe) is supplied to the servo. Did you do this?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 15-11-2010, 17:53
tommy0019's Avatar
FRC #2957
Re: servos problems
Thanks we forgot the jumpers, it should work fine now, we just have to locate the jumpers. Thank you agian.
Servos team3329 Programming 2 16-04-2010 09:59
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Servos Mike Yan Kit & Additional Hardware 1 09-02-2003 00:53
servos Alex Cormier Kit & Additional Hardware 1 14-01-2003 11:12
