Go to Post Good luck, and may the FIRST be with you. - Leav [more]
Unread 25-11-2010, 23:19
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Python virtual speed controllers!
Hello all.
I know this should go in the python forum, but this can affect everyone.
here is the code, just put it all in one directory, running directions below:
debug_test.py
#!/usr/bin/python
import cmd
test = None
var = []
def do_args(args):
    print args.split()
def do_driver(args):
    arg = args.split()
    test_passed = False
    if len(arg) > 0:
	var1 = float(arg[0])
	var2 = float(arg[1])
	var3 = float(arg[2])
    else:
	var1 = 0.5
	var2 = var1
	var3 = var1
    try:
	import outputs, testing
	test = outputs.Driver(1,2,3,4)
	print
	print "Doing tankDriveRaw:"
	test.tankDriveRaw(var1, var2)
	print
	print "Doing holonomicDriveRaw:"
	test.holonomicDriveRaw(var1, var2, var3)
	print
	print "testing the fancy list-based versions, tankDrive then holonomicDrive"
	test.tankDrive([0, var1], [0, var2])
	test.holonomicDrive([var1, var2, 0, var3])
	print
	print "Don\'t forget to stop the robot"
	test.stop()
	test_passed = True
    except:
	print "fail"
    if test_passed:
	print "The robot is able to move, test passed"
class tests(cmd.Cmd):
    def __init__(self):
	cmd.Cmd.__init__(self)
	self.prompt = "2412_debug# "
    def do_driver(self, args):
	"""Actually tests the driver class I wrote"""
	return do_driver(args)
    def do_EOF(self, args):
	import sys
	print
	sys.exit(0)
    def do_args(self, args):
	"""A dummy to test variable handling"""
	return do_args(args)
    def do_show(self, args):
	"""A failed show command"""
	arg = args.split()
	if arg[0] == "test":
	    print test
	if arg[0] == "ver":
	    print "Version 0.2, Touko"
	else:
	    for n in var:
		if arg[0] == n:
		    print var[n][arg[0]]
    def do_var(self, args):
	"""Sets variables, can't do much else :("""
	args = args.split()
	if args[0] == "test":
	    test = args[1]
	    print "test case"
	else:
	    var.append({args[0]:args[1]})
	    print "other case"
	print "variable " + args[0] + " set to " + args[1]
    def do_showVars(self, args):
	"""Shows all raw variables"""
	args = args.split()
	for n in var:
	    print n
    def do_prompt(self, args):
	"""Allows you to change your prompt"""
	args = args.split()
	self.prompt = args[0]
    def do_cure_cancer(self, args):
	"""the obligatory easter egg"""
	args = args.split()
	print "sorry, my mentor told me to not make programs cure cancer :P"
main = tests()
main.cmdloop()
outputs.py
#not the main class
try:
    import wpilib as wpi
except:
    import testing as wpi
class Driver:
    def __init__(self, port1, port2, port3, port4):
        self.FL = wpi.Victor(port1)
        self.FR = wpi.Victor(port2)
        self.RL = wpi.Victor(port3)
        self.RR = wpi.Victor(port4)
        self.vicList = [self.FL, self.FR, self.RL, self.RR]
    def stop(self):
        """Stops the robot, useful for everything"""
        self.tankDriveRaw(0, 0)
        print "Robot Stopped"
    def tankDrive(self, stick, stick2):
	left = stick[1]
	right = stick2[1]
        try:
            self.vicList[0].Set(left)
            self.vicList[1].Set(-right)
            self.vicList[2].Set(left)
            self.vicList[3].Set(-right)
        except:
            print "tankDrive at " + str(left) + " and " + str(right)
    def holonomicDrive(self, xboxController):
	power = xboxController[1]  #y-axis, first stick
	strafe = xboxController[0] #x-axis, first stick
	spin = xboxController[3]   #x-axis, second stick (x...[2] is the trigger axis)
        fl = power + strafe + spin
        fr = power - strafe - spin
        rl = power - strafe + spin
        rr = power + strafe - spin
        print "holonomicDrive called"
        self.FL.Set(fl)
        self.FR.Set(fr)
        self.RL.Set(rl)
        self.RR.Set(rr)
    def tankDriveRaw(self, left, right):
        print "tankDriveRaw at " + str(left) + " and " + str(right)
    def holonomicDriveRaw(self, power, strafe, spin):
        print 'holonomicDriveRaw called'
        self.FL.Set(fl)
        self.FR.Set(fr)
        self.RL.Set(rl)
        self.RR.Set(rr)
inputs.py
#inputs.py
def system():
    pass
try:
    system.runPlace = 0 # robot
except:
    system.runPlace = 1 # laptop
class Attack3:
    def __init__(self, port):
	self.port = port
	self.joy  = wpi.Joystick(self.port)
	print "New Attack3 configured at port " + str(port)
    def getAxies(self, x_axis, y_axis):
	"""Returns a list in the format of [arg1, arg2]"""
	resultant = list()
	resultant.append(self.joy.GetRawAxis(x_axis))
	resultant.append(self.joy.GetRawAxis(y_axis))
	return resultant
    def getStickAxes(self):
	return self.getAxies(2,1)
    def getThrottle(self):
	return self.joy.GetRawAxis(3)
    def getButtons(self):
	r = [] #r is of type list
	for n in range(1,12):
	    r.append(self.joy.GetRawButton(n))
	#To the tune of ghostbusters:
	#When there's an annoying problem, that you need to solve?
	#whatcha gonna use?
	#A FOR LOOP!
	#when there's a lot of data
	#that you need to parse
	#whatcha gonna use?
	#A FOR LOOP!
	#I ain't afraid of no macs
	#XD
	return r
    def getTrigger(self):
	return self.getButtons()[0]
class Xbox():
      self.port = port
      self.a = 1
      self.b = 2
      self.x = 4
      self.y = 3
      self.lb = 6
      self.rb = 5
      self.back = 7
      self.start = 8
    def bufferIt(n):
	if abs(n) < 0.2:
	    n = 0
	return n
	resultant = list()
	resultant.append(bufferIt(self.joy.GetRawAxis(x_axis)))
	resultant.append(bufferIt(self.joy.GetRawAxis(y_axis)))
	return resultant
    def getAllAxes(self):
	r = list()
	for n in range(1,6):
	    r.append(bufferIt(self.joy.GetRawAxis(n)))
	return r
    def getButton(self, button):
	return self.joy.GetRawButton(button)
    def getButtonList(self):
	r = list()
	for n in range(1,9):
	    r.append(self.joy.getRawButton(n))
	return r
testing.py
#This file should emulate enough of wpilib to make it usable for testing
#TODO: use pygame to get joystick inputs from actual joysticks
def limit(n):
    if n > 1.0:
	return 1.0
    elif n < -1.0:
	return -1.0
    else:
	return n
class Victor:
        self.port = port
        print "Virtual Victor set up on port " + str(port)
        self.speed = float()
    def Set(self, speed):
        """***FOR TESTING PURPOSES ONLY***
       This "sets" the virtual Victor to any arbitrary speed"""
        speed = limit(speed)
        print "on port " + str(self.port) + " the speed is now " + str(speed)
        self.speed = speed
    def Get(self):
       This emulates the wpilib.Victor.Get function"""
        return self.speed
class Joystick:
        self.port = port
        print "New joystick set up at port "+str(port)
    def Get(self):
        return 0.5
def speedReport(list_obj):
    """Use this for the driver object"""
    for n in list_obj:
        n.Get()
def IsDisabled():
    return False
def IsAutonomous():
    return False
def IsOperatorControl():
    return True
def IsEnabled():
    return True
class dummyDog:
    def SetEnabled(self, var):
        pass
    def SetExpiration(self, var):
        pass
    def Feed(self):
        pass
def GetWatchdog():
    return dummyDog()
run debug_test.py
its a shell interface to my tests, you can throughly ignore show and var, it was a part of another project i attempted (and failed at)
driver does the cool stuff
have fun!
Unread 30-11-2010, 10:21
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Python virtual speed controllers!
It should be noted that the python interpreter ported to the cRio is python3, not python2. So, if you were to run the robot.py on there, it would have some problems, particularly because of the print statement is now a function in python3.
Unread 30-11-2010, 16:13
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
I'm pretty sure this code was NOT intended to be run on a robot, and is meant to be a simulation run on a computer.
Unread 30-11-2010, 16:31
virtuald's Avatar
RobotPy Guy
Referring to the top of the file:
try:
except:
That import statement seems to refer to the wpilib that is available in the python interpreter ported to the cRio. So, it could theoretically be run on the robot, if the bugs were fixed. Might not be useful, but it could work.
Also refer to inputs.py, it has the same thing that switches the input device from a joystick to predetermined values.
Unread 30-11-2010, 16:56
Bot190's Avatar
Ok, now I've confused myself, Looking at what you said, then looking at the code, and what the OP said, I have no clue what its meant to do, and how its meant to be used. Can the OP clarify this?
Unread 30-11-2010, 21:47
1 * 4 != 14
sorry,
I didn't realize it was py3 on the robot, i will fix the prints.
What you can do with this is using the cmd framework I have set up, you can essentially have your laptop run any code the robot would (when this is done, of course) and get a result you can use a whiteboard to draw out.
This code will also (hopefully) run on robotPy.
Can I please have feedback on things such as my coding style? It would help a lot.
Sorry for the confusion.
Speed Controllers Liu_yiang General Forum 11 07-02-2009 20:12
Speed controllers.... Denman Technical Discussion 14 07-10-2004 15:19
speed controllers archiver 2000 5 24-06-2002 00:19
Speed Controllers archiver 2000 1 23-06-2002 23:01
Speed Controllers... Tom Schindler Technical Discussion 4 13-12-2001 17:26
