Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 01-12-2010, 18:20
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Drive Control Systems: SOAD and Wii
Last winter, as our team was deciding on our driver controls, debating tank, arcade, and other ideas, we came on a really cool idea: Semi-omni-arcade drive. The driver would point the joystick in the direction it needed to go, and using a gyro, the robot would go to that direction relative to the driver. After some testing, we decided it would be a better summer project, and went on our merry way. Later, when it was summer, we were thinking of cool drive control systems and thought the Cypress's accelerometer would be a cool way to drive.
Now, we have both of these working, and they are just cool! The Cypress board was surprisingly very easy, and was soon called a "Wii" drive by the rest of the team after I finished it one meeting and everyone wanted to try it.
Videos and Code: http://thecatattack.org/DriveSystems
The code also has a white ball on green tracking function, and a CANGroup that groups 1-4 CANJaguars in a sync for left/right so you can still use the RobotDrive class.
Also, when you enable, hold down button 11 for SOAD, 12 for tracking, and press 10 at any point to reset (or switch modes). It defaults to Wii drive.
Watchdog.Kill();
Unread 01-12-2010, 19:29
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Drive Control Systems: SOAD and Wii
That's pretty sweet. Now see if you can make it into a glove and point to where you want the robot to go!
Academic Student (Forever)
Unread 02-12-2010, 00:15
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Now you're playing with power
Unread 02-12-2010, 03:32
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Nice work. The SOAD is pretty interesting. I've seen similar things done for fully holonomic robots before, but it's cool to see the same behavior from a limited degree-of-freedom bot.
-Joe
Unread 03-12-2010, 00:26
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Have you tried using an actual Wii controller?
Oh and whats the accuracy on you accelerometers? I've been messing with using an actual Wiimote and I've noticed that the values constantly change, even when I'm not moving.
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 03-12-2010, 14:44
byteit101's Avatar
No, is it just a USB connection?
I have not inspected closely the values, but from a driver standpoint, it seems to be fairly consistent. We had it driving for over 5 minutes, and at the end, I don't remember any odd behavior (except for the movement getting a little weaker, but the robot we are using drains the battery after about 3 minutes when all systems are on)
Watchdog.Kill();
Neat demonstration of proportional and PID control systems Joe Johnson Technical Discussion 12 16-03-2010 22:18
Holonomic drive train and field-based control dmlawrence Technical Discussion 20 18-11-2007 22:17
White Paper Discuss: Team 670 - Universal Drive Systems: Design and Analysis ChrisCook Extra Discussion 13 01-07-2005 23:41
Control Systems dbeck103 General Forum 2 30-09-2003 12:49
Control Systems archiver 2000 1 23-06-2002 22:15
