Go to Post Our team has a forum..... chiefdelphi.com Ok I had to say it. - Mike Martus [more]
Unread 06-12-2010, 22:01
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Talking iPhone Driver Station, No Computer Needed
Title pretty much says it all.
I have created a iPhone/iPod touch (sorry iPad users) application, that allows for full, 100% control of the robot without the need for the driver station, becasue the application IS the driver station.
The app features the ability to
  • Enable/Disable the robot
  • Teleop/Autonomous Control
  • Read battery voltage and robot state
  • Full digital and analog I/O
  • 10 joystick buttons
  • 2 virtual joysticks
  • accelerometer control
Future Abilities will include
  • Camera View
  • Robot debug messages
  • Anything suggested that is "reasonable"
This app will have a few final improvements to be made (icons, splash screen, etc) but should be submitted to apple shortly. Updates will be posted on the state of the applications submission progress
Also attached are a few images of what the UI looks like so far. As always on CD, any and every comment/suggestion is more than welcome.
Edit:
This application also requires no flashing/specialized reprogramming on the robot to work, joysticks are initialized and read in as normal.
Name:	Photo Dec 06, 3 40 10 PM.jpg
ID:	9470  Click image for larger version
Name:	Photo Dec 06, 3 40 37 PM.jpg
ID:	9471  Click image for larger version
Name:	Photo Dec 06, 3 40 47 PM.jpg
ID:	9472  Click image for larger version
Name:	Photo Dec 06, 3 41 02 PM.jpg
Unread 06-12-2010, 22:22
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: iPhone Driver Station, No Computer Needed
Can I ask how you got it to communicate with the robot without the driver station.
I always thought the communication was proprietary.
Unread 06-12-2010, 22:23
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Thumbs up Re: iPhone Driver Station, No Computer Needed
This is great news!
But what about those that do not use the I-phone/I-touch?
Is the program able to be transfers to other systems?
Are you working on an I-Pad version?
Can this be uses for a touch screen laptop computer?
These would be excellent options for various other input devices.
Again, Great work.
Unread 06-12-2010, 22:31
FRC #3357 (Comets)
@davidthefat
#EDIT
I used a mix of packet analyzer (wireshark - a program to analyze the packets being sent to/from the drivers station) and packet definitions found in WPIlib to determine how the robot and driver station communicated so I could make an iPhone application that would communicate in that manner.
@MrHance
It could be written for other systems without a tremendous amount of work, more details about what system you would like it made for would be helpful. Also, i would like to make an iPad version of this to test with, but the lack of an iPad to test with is kinda an obstacle (however i might be able to borrow one from someone)
Unread 07-12-2010, 18:30
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
I have some experience with iOS programming as well as an iPad. I'd be happy to beta test the ipad version or even help with the app if you would find that agreeable. I can always email you copies of NSLog's output as well as safes of instrument runs. (At least I think you can save trials from instruments)
Good luck
Oliver
Unread 07-12-2010, 18:59
raymohi2181 raymohi2181 is offline
FRC #2181
raymohi2181 is an unknown quantity at this point
I have an iPad, so I could test it and send feedback. If you would like. The current robot I would use has a verity of custom senors and outputs.
-Ray H.
Unread 07-12-2010, 19:15
DDSLoan96's Avatar
DDSLoan96 DDSLoan96 is offline
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
DDSLoan96 is an unknown quantity at this point
When will it come out and what is it going to be called??
Unread 07-12-2010, 19:51
FRC #3357 (Comets)
It will most likely be called simply "Drive Station" or "FRC Driver Station" and it will be submitted to apple as soon as I make an icon and a splash image for it.
Unread 07-12-2010, 21:09
MrHance's Avatar
Question Re: iPhone Driver Station, No Computer Needed
I have been following this thread with great interest as I am sure that FRC is as well.
I am not a programmer so bear with me.
I am a Design Engineer so these questions are to help me understand the relationship of the system with the existing FRC controls.
Some other questions as far as using it at comps.
Will it be legal?
Will the WiFi signal interfere with other teams that maybe using the same applications or other application?
What is the range limitation?
How does this interface with the driver station controller?
Will this app. work with other systems like VEX, NURC and LEGO controll?
As I think of other applications I will post the questions here.
Agian, Great work and I hope this will help you all make it thru college.
Unread 07-12-2010, 21:38
FRC #3357 (Comets)
MrHance, I'm glad you brought that up, and that is probably something I should have stated in the opening post, this would not be a legal control system during competitions, due to the fact that it is WiFi based and any wireless is not allowed on the field during a match except for the wireless the robots are using. On a side note to that however, I am looking into a possible way this could be modified to be a legal control method, but its unlikely that it would be very practical if it were in working, legal condition.
As far as your question of "How does this interface with the driver station controller?"
This is actually a complete replacement for the drive station, this application runs 100% independently by itself with no computer required anywhere in the system.
And No, this application is not programmed to work with the VEX,NURC, or LEGO controllers, it can only control FRC robots.
This app is mainly expected to be used for demonstration purposes, or in any circumstance where it is inconvenient/impractical/impossible to use the driver station. As far as the range of the system is concerned, if the iPhone is within the range of the WiFi network, and so is the robot, they you have control, which typically, line of sight would be about 200-300 feet, and with many walls in between about 100 feet. If you have any more questions feel free to ask me.
Unread 12-12-2010, 14:27
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
This is all well and good, something I am really interested in actually buying (I never buy apps for my itouch), but I have a few questions:
1. If it connects via wifi, what, if anything would have to be done to the gaming adapter on the robot?
2. For joysticks, does the app have virtual joystics on screen, or does it use the accelerometer in the device?
3. How would a user go about changing user I/O? I personally think this needs to be easily accessible at all times.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 12-12-2010, 14:47
FRC #3357 (Comets)
1) no changes need to be made to the gaming adapter
2)it uses 2 onscreen joysticks (video page 2) and the accelerometer
2) there is a screen for setting/reading digital IO and the analog inputs
Unread 12-12-2010, 14:58
AKA: Alex
After so many "gaming adapter problems" threads, it is nice to hear that you seem to have put a lot of thought into this app. I look forward to getting my hands on it. One thought: it might be nice to have the capapbility to set the accelerometer as two joystick axis...
-Alex
Unread 06-12-2010, 22:27
Ethan E Ethan E is offline
FRC #1683
Ethan E is an unknown quantity at this point
I knew that creating a custom dashboard was (relatively) simple, but was under the impression that the driver station (I/O, joysticks, enable/disable) was locked down by FIRST. Did they publish an API, or did you reverse engineer it, or what? (Sorry if the answer is obvious, I don't frequent CD too much)
Unread 06-12-2010, 22:37
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
really want it, cant wait to try it out and possibly break our robot with it.
Bacon
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
Personal Computer Problem With FRC Driver Station Pewter_Newb General Forum 2 19-01-2010 23:26
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
