Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Unread 08-12-2010, 09:43
Talguy Talguy is offline
FRC #2168
Talguy is an unknown quantity at this point
WebDMA for Labview?
Has anyone created soemthing similar to the webdma library for labview. We would like to be able to tune our robot in realtime with out have to constantly upload new builds onto the bot for testing.
Unread 08-12-2010, 10:25
Re: WebDMA for Labview?
If you run from source (push the run button), any panel can be opened, indicators and parameter inputs viewed, panel controls can be changed.
You can of course also probe, breakpoint, single step, profile, and use the other debugging tools.
Once you've built and deployed, the panels have been stripped, and this is not possible, but you can still publish data to the dashboard or via any other mechanisms -- UDP, TCP, etc.
Greg McKaskle
WebDMA (robot tuning via a web interface) w/easy install released virtuald C/C++ 4 06-08-2010 12:17
Interactively tunable PID Controller class via WebDMA virtuald C/C++ 0 23-01-2010 01:47
WebDMA: Tuning your robot via a web interface (C++) virtuald Programming 15 20-01-2010 00:17
Backup for LabView matanost Programming 2 14-02-2009 08:06
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
