Go to Post the always so humble metal-in-motion.....i know your tricks; you all are gonna have a killer robot as usual.... - Stephen Kowski [more]
Unread 09-12-2010, 01:42
ehlochbr ehlochbr is offline
FRC #2990
ehlochbr is an unknown quantity at this point
Error: within this context
I'm trying to add the code for the Axis camera and I keep seeing this error when I build the project "error: within this context".
#include "WPILib.h"
#include "Gamepad.h"
#include "Vision/AxisCamera.h"
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Gamepad controller;
AxisCamera camera;
public:
RobotDemo(void):
myRobot(10, 9, 2, 1), // these must be initialized in the same order
controller(1)
{ <------ERROR HERE
All I did was add the AxisCamera header file and the identifier (AxisCamera camera).
What am I missing? Thanks.
Unread 09-12-2010, 03:16
Re: Error: within this context
You've added a data member called camera, of type AxisCamera, no problem there. But the code you've included has a constructor with an initialization list, and you haven't added a value for camera field.
Not being that familiar with the C++ WPI code, the issue is likely that the AxisCamera doesn't have a default constructor or for some other reason, the compiler wants camera to be assigned using the initialization list.
Try putting
camera(???)
after the controller(1) line and before the {. Replace ??? with the parameters required for an AxisCamera object to be initialized.
Gotta love compiler error messages sometimes.
Greg McKaskle
Unread 09-12-2010, 09:01
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
AxisCamera is a singleton. You shouldn't be calling the constructor directly. Try this.
AxisCamera& camera;
//In your constructor do this
camera = AxisCamera::GetInstance();
Last edited by Dave Scheck : 09-12-2010 at 10:13. Reason: Changed my pointer to a reference to match the prototype
Unread 09-12-2010, 09:59
FRC #2990
Thanks for the reply. It looks like I have a different problem now. When I try to implement your suggestion and use:
I get an error that says "cannot convert 'AxisCamera' to 'AxisCamera*' in assignment". Can you explain what this means?
Thanks again.
Unread 09-12-2010, 10:09
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
You should declare the camera as:
AxisCamera &camera;
Unread 09-12-2010, 10:15
Thanks for the correction mikets. I misread the header when I wrote my initial post. I updated it to have the reference declaration instead of a pointer.
Unread 09-12-2010, 17:54
FRC #2990
I really appreciate both of your replies, but making the corrections you suggested has led me to another problem.
	Gamepad controller;
	AxisCamera& camera;
public:
	RobotDemo(void):
		controller(1)
	{                                     <-------------------------ERROR HERE
		GetWatchdog().SetExpiration(0.1);
		camera = AxisCamera::GetInstance();  <--------ERROR HERE
The first error says "uninitialized reference". How do I initialize it?
The second error gets me back to where I started. It says "error within this context".
This feels like one step forward then two steps back. Thanks for your help.
Unread 09-12-2010, 18:01
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
You need to initialize all non pointer members before the body (and especially references, they only have one life)
try this:
	Gamepad controller;
	AxisCamera& camera;
public:
	RobotDemo(void):
		controller(1),
camera(AxisCamera::GetInstance())
Also, "error within this context" is part of a larger error, open the build console and find the red lines to find the rest of the message. many messages are 2 or more parts.
Ex (bold is error in code)
file.cpp: In constructor `ZomBDashboardPacketSender::ZomBDashboardPacketSen der()':
file.cpp:301: error: uninitialized reference member `ZomBDashboardPacketSender::hp'
WPILib/Dashboard.h:58: error: `void Dashboard::operator=(const Dashboard&)' is private
file.cpp:302: error: within this context
Watchdog.Kill();
What's this number 80 in error math? K.Porter Programming 3 25-01-2007 18:28
Glitches Eliminated using Interrupt Context Saving, BUT ... mluckham Programming 22 09-01-2007 17:19
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
What is this error message? chantilly_team Programming 3 22-01-2005 10:09
Explain this link error? Larry Barello Programming 1 16-01-2004 11:06
