Go to Post Start simple and build up. - Mark McLeod [more]
Unread 21-12-2010, 16:57
CaptainKemp CaptainKemp is offline
AKA: Morton
FRC #0888 (Robotiators)
CaptainKemp is an unknown quantity at this point
Exclamation cRio Power Light Not Turning on and no Activity
Hello all,
I'm from team 888 and our cRIO seems to me that it is broken in some way. When attached into our robot, the power light has stopped turning on and the cRio will not do anything. I have redone the cables to the cRio and checked voltage drops over the whole system. Everything seems as though it should work.
After all these tests didn't tell me anything, I took the cRio out of the robot and made an incredibly simple circuit by connecting power to the Power Distribution Board and connecting the 24V out into the cRio. I turned it on and nothing happened. I changed out the connectors to see if they were the problem and tried again. Nothing.
This is my last attempt at finding a solution until I reccomend to my coach that we either send the cRio out to be fixed or to just by a whole new cRio.
Please Help Me!
Thanks,
Morton
Team 888
Unread 21-12-2010, 17:11
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: cRio Power Light Not Turning on and no Activity
Do you have a picture of your set-up? A picture may help us see something that might cause it to not work, as opposed to a limited description.
Unread 21-12-2010, 17:21
AKA: Morton
As you can see I broke it down to the barebones set up to see if the power would turn on. If you cannot see the lights: All lights one power board are on and all lights on cRio are off
Morton
Team 888
"Any sufficiently advanced technology is indistinguishable from magic." - Clarke
Unread 21-12-2010, 17:34
Jason Law's Avatar
Team Captain
Did you try running a program? Is it possible that the connection to the lights was loose, but the cRIO is still working? Also, I can't see it in the picture, but i'm assuming you wired the positive and negative correctly (from the PD to the cRIO)?
Unread 21-12-2010, 17:44
AKA: Morton
While connected to the robot in the same configuration it would not respond to anything even by tether
And yes, red to red, black to black
Morton
Team 888
Unread 21-12-2010, 17:46
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by CaptainKemp View Post
Attachment 9528
Silly questions, but I have to ask. Are you certain the correct set of terminals are being used on both ends of the +24vdc cable. Is your polarity correct?
Unread 21-12-2010, 18:00
AKA: Morton
There's no silly questions on here bilbo, I'm looking for any solution at this point.
But yes I checked the configuration for the power connectors to make sure that wasn't happening.
Morton
Team 888
Unread 21-12-2010, 18:11
There was a team that had this happen at Brunswick Eruption this Fall.
Theirs was fixed by following the cRIO cleaning instructions.
If the cRIO remains inoperable then I'd suggest contacting the NI Tech help line (middle of the page).
There is an internal fuse that could be blown. Only NI can replace that though.
Unread 21-12-2010, 18:14
billbo911's Avatar
One last thing to check is that you don't have a bunch of debris inside the cRio that might be shorting out the power bus. Try vacuuming out the cRio and check it again.
If you know for certain that you have +24 vdc at the power input to the cRio, as measured with a VOM, then there is a good chance an internal fuse has blown.
Arrgg, Mark beat me to it.
Unread 21-12-2010, 19:00
DonRotolo's Avatar
Back to humble
FRC #0832
Last year after Champs we crated a perfectly functional robot. When it arrived in NJ the cRio was dead as you described. We cleaned it and everything, no luck.
NI's repair service was absolutely fantastic in repairing it quickly and now it works perfectly again (and, in this case, the repair was free). That's one reason why we use their stuff at work.
So, "What Mark Said"
Unread 21-12-2010, 19:08
Don, may I ask what they fixed?
Unread 23-12-2010, 16:22
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, you may.
Oh, you already did.
I don't have the details in front of me but they 'applied engineering fix #xxxx" something to do with the power system. A fuse could've been it, not sure.
Unread 23-12-2010, 16:31
Hmm. "Engineering fix" sounds like they didn't just replace with identical parts but rather upgraded something to address a known problem. Not that that's bad. It actually sounds like a good thing.
Unread 22-12-2010, 03:26
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Hello all,
Please Help Me!
Thanks,
Morton
Team 888
We had the same problem.
Know this:
National Instruments will fix your cRIO for free if you do an RMA. They will return it within two weeks of receiving it.
Your issue is probably dust or a blown fuse, but if you're uncertain, you can ship it down and they will fix it for you.
It's unfortunate this happened right before build season.
-- Marshal Horn
Unread 22-12-2010, 03:50
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
There is a fuse inside the cRIO. It could have been blown. We had two cRIOs that had their fuses blown last season. We called NI and arranged to have two replacement cRIOs shipped 2nd day to us. After we received them, we shipped the broken ones back to them. Of course they took down our credit card number in case we didn't ship them back. If you want to confirm this is indeed the cause, open up the cRIO by removing the screws on the bottom side of the cRIO and you will find a white surface mounted fuse near the dip switches. Put an ohm meter across it. If it doesn't read zero ohm, it's blown. Caution: disconnect power before you do the ohm check.
cRIO not turning on!!! MHSrobotics2853 Electrical 14 18-02-2010 08:58
cRIO and Laptop Not Communicating ERROR CODE 63 bhavik15 Programming 7 27-01-2010 15:04
Not too much activity here... Kevin Thorp 3D Animation and Competition 20 27-01-2009 22:02
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
