Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 23-12-2010, 13:17
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
[FTC]: Cutting Chain
Hi Everyone,
We got some of the Tetrix chain recently, however we didn't order a chain cutter. Does anyone have any experience cutting chain without a chain cutter?
Thanks,
Lemiant
Unread 23-12-2010, 14:10
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: [FTC]: Cutting Chain
I've never tried it but if you were careful, you could try to punch out the pin with a center punch and a hammer.
Or just get yourself a chain tool, they're worth it.
-vivek
"we don't build robots, we build people"
Unread 23-12-2010, 16:01
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Sounds like he got it spot on. If you don't have the tool you have to be VERY careful and well its kind of a pain in the butt to do it without a chain break. I would recommend something simple from your local hardware store if they have any you probably can find a bunch of chain breaks online if you search around.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 23-12-2010, 21:03
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We found that the Dark Soul Chain Break is the best on the market. I wish I could find something similar for #35's.
http://shopping.netsuite.com/s.nl/c....t.A/id.2258/.f
Unread 24-12-2010, 05:16
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
You can also use a dremel to grind off the ends of the two posts. Just be sure to get the right pair, or you'll make the chain shorter than you wanted.
Unread 24-12-2010, 18:41
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
If you have a press in your shop, along with a center punch that is your best bet. A bit safer than a hammer considering you use the amount of force you want rather than just hitting it. It really works just like a chain break if you do it right.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 25-12-2010, 22:58
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
The Dark Soul breaker and re-assembly tool is bar none the best I've ever used.
That's why we endorse and sell it.
Dark Soul #25 Breaker/Re-assembler
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 26-12-2010, 00:37
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I've used a bicycle chain breaker with a ground down pin before, rather difficult though.
Unread 31-12-2010, 16:04
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
+1. I prefer doing it this way over the standard chain-breaker tool.
Unread 02-01-2011, 17:39
AKA: Andrew Remmers
If you did this wrong couldn't you severely weaken the chain?
Unread 02-01-2011, 18:07
wilsonmw04's Avatar
Coach
yep, not to mention all the metal shavings in the chain itself. My biggest worry would be bending the chain during the grinding process. Bent chain doesn't work too well in my experience.
[FTC]: Chain Help? Letsroll FIRST Tech Challenge 1 05-02-2010 16:32
[FTC]: Chain Break Andrew Remmers FIRST Tech Challenge 2 18-10-2009 11:34
[FTC]: Cutting Tetrix Metal blackbrigadeer FIRST Tech Challenge 3 12-01-2009 08:56
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
