Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 23-12-2010, 20:16
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
ErikRantapaa is an unknown quantity at this point
stumped - can't get servo example working
I am trying to run the servo example vi, but the digital sidecar status led is always in fast flashing mode.
My configuration:
- DB37 cable from module 4 (NI 9403) to digital sidecar.
- 12V Wago connector from PD board to digital sidecar
- no jumpers on the digital sidecar (anywhere)
- nothing else connected to the digital sidecar
When I power the system on, the BAT, 5V and 6V leds turn on. No other leds are on.
When I deploy the servo example, the status led will start to fast flash. (The flashing begins mid-way through deployment.)
Fast flash continues while the application is running.
I get the same behavior if I have a hobby servo (Futaba 3003) connected to a PWM channel (with or without the power jumper) and deploy the application. Servo doesn't respond to the dial control.
Any ideas? Thanks!
Update found this forum tread which sounds like it might be related to my problem [need to enable the robot from the driver station]:
http://www.chiefdelphi.com/forums/sh... ital+sidecar
If so - what would be easiest way to get the servo example working? Do I have a create custom Dashboard VI? I'm not using the Classmate, just my own laptop.
Thanks!
Unread 23-12-2010, 21:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: stumped - can't get servo example working
I am told by our programming mentor that "you can't run the robot without the driver station".
Unread 23-12-2010, 21:34
DOWNLOAD 2010 DRIVER STATION FROM NI; WORKS ON ANY PC
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Unread 11-01-2011, 16:36
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
"no jumpers on the digital sidecar (anywhere)"
lol you need to put a jumper on the input next to the pwm slot the servo is connected to on the digital sidecar. They do not come with the digital sidecar
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 11-01-2011, 17:35
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
There is a little 2 pin spot where you insert the jumper. LOL I spent a full week last year trying to get servos working. My code was perfect, but it only took one question to the electrical leader to fix it
Unread 11-01-2011, 23:46
darkorbit's Avatar
Electrical?!
AKA: Jin Lem
lol I had fun with the programmers last year haha I made them look it up in the manual even though I knew what the problem was haha
Unread 18-02-2013, 18:40
tmccalister tmccalister is offline
FRC #2985
tmccalister is an unknown quantity at this point
What does this jumper look like?
Unread 18-02-2013, 23:05
It looks like a tiny square of plastic, just under 1/4" on a side. The KOP checklist says you should have received four black ones along with a bunch of other things in small electrical parts bag. It fits over two pins sticking up a tenth of an inch apart on the Digital Sidecar, adjacent to the three-pin PWM connector.
simple problem; can't build example projects kennypu C/C++ 13 03-02-2010 21:21
Labview Joystick Input Example code not working jsprigg Programming 10 28-01-2010 16:53
Servo Camera Example Servos don't work Booksy FRC Control System 10 04-03-2009 17:09
Control System Stopped Working after switching into Auto mod - Was: Help were stumped Tack610 FRC Control System 9 29-01-2009 19:48
