Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 26-12-2010, 18:00
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
pic: off season chassis
Unread 26-12-2010, 18:03
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: pic: off season chassis
This is very intriguing to me. I'm assuming the middle (omni) wheel is offset lower than the traction wheels. This would mean the chassis is always sitting on 2-traction wheels + 2-omni wheels at any given time.
The weird thing is... I imagine the turning point of the robot would drastically shift from the front to the back depending on which set of wheels the robot is sitting on. (At least, this is what physics tells me).
Have you driven it yet? How does it handle?
Is there a reason you didn't go with front/read omnis and middle traction wheels? This would result in the same 2+2 configuration, but you'd have a consistent (centered) turning point.
-John
Unread 26-12-2010, 19:56
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Silly John...
That IS the whole chassis!
The game this year is obviously going to be a scooter-like thing!
Unread 26-12-2010, 22:12
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
I tend to agree with JVN's comments, with this addition: Seems to me that by putting the omni's in the middle (presumably dropped the obligatory 1/8"), you lose your resistance to sideways pushes.
"It's NOT Just A Robot Thing!"
Unread 26-12-2010, 22:24
ttldomination's Avatar
Sunny
And are we looking at the outer part of the chassis? I see two sprockets on the middle wheel and one sprocket on each outer wheel, so I'm wondering where the motor goes...
1648: 2013-2014
5283: 2015
Unread 26-12-2010, 22:37
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Is it realy strong, i would like to do something like this because our normal chassis is extremely heavy, but strong
Unread 26-12-2010, 23:21
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
I'm guessing the center wheel IS DROPPED so it will function as a normal 6WD chassis. This is so because we all know on most 6WD there are only 4 wheels on the ground so it can rock and turn? right? so the middle wheels act as the turning point so its like a 4WD with omni's in front.
Do i make sense? Because it was a little hard to explain trough the 'net
Unread 26-12-2010, 23:31
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
If the CG is fairly balanced front to back I don't think the traction wheels would get enough grip to greatly affect how the robot turns in place. I suspect you could probably pull some of those fun maneuvers from Lunacy though, like the sideways slides and the backwards-180-forwards whip around. Looks like fun to play with!
Unread 26-12-2010, 23:41
jsasaki's Avatar
AKA: Jun Sasaki
This is great I put this up to see what kind of comments i would get .. to clarify things up... we can swap all 3 wheels and I think we were also looking at going for all 6 wheels to be plaction style wheels. we are going to run it on friday soooo we'll see
Unread 27-12-2010, 00:37
JVN JVN is offline
@JohnVNeun
Jun,
Try it in the configuration shown! If nothing else I'm extremely curious how it performs. I don't know if it will perform well (in fact I suspect it won't)... but you'd be my hero if you tried it out and took some video...
I bet if nothing else you could teach some students a cool lesson on drivetrain turning (the video would also be giving me a tool I could use to teach the same things).
-John
Unread 27-12-2010, 01:47
Chris is me's Avatar
AKA: Pinecone
I think this is really cool. Imagine a robot that could shift its CG at will by moving an arm or a weight. You could pivot among whichever axis you chose, if for whatever reason you didn't want to rotate about your center.
Unread 26-12-2010, 23:33
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
The middle wheel will simply make it so only a front set and middle set or back set and middle set are on the ground at a time. Thus, it's treated like any four wheel drive, except the issue with this 4 wheel drive will be that half of the mass is located beyond the sliding wheel. It certainly appears that resistance to rotation from robot-to-robot contact will be reduced, but this may be intentional (It's an interesting concept that could be explored, IMO).
Attending: MN Duluth Regional
pic: Off-Season Kicker Design rahilm Extra Discussion 22 08-07-2010 19:23
pic: Off Season Proto type joeweber Extra Discussion 6 02-01-2009 12:46
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
