Go to Post Magic Smoke. One whiff and you never forget. - JohnBoucher [more]
Unread 29-12-2010, 15:27
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
jars: creating and adding
I am working on packaging up the ZomB Dashboard bindings for java, and I have two questions: How do you create a jar as a library? and How do you add it to a project so it can use the jar?
When I build a project, it produces a jar file in suit/project_1.0.0.jar. Is this a good jar file? When I drop it on a project, or add it in the ant classpath, it produces errors:
init:
No to.jar.file specified.
Using "suite\RobotTemplate_1.0.0.jar"
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
clean:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
Compiling 1 source file to C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\src\edu\wpi\first\wpilibj\templates\RobotTemplate.java:10: package org.thecatattack.System451.Communication.Dashboard does not exist
import org.thecatattack.System451.Communication.Dashboard.*;
C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\src\edu\wpi\first\wpilibj\templates\RobotTemplate.java:22: cannot find symbol
symbol  : class ZomBDashboard
location: class edu.wpi.first.wpilibj.templates.RobotTemplate
        ZomBDashboard zomB = ZomBDashboard.getInstance(ZomBModes.TCP, "10.4.51.5");
symbol  : variable ZomBModes
symbol  : variable ZomBDashboard
4 errors
C:\Documents and Settings\***\sunspotfrcsdk\ant\compile.xml:48: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 18 seconds)
Watchdog.Kill();
Unread 06-01-2011, 18:16
Datalore Datalore is offline
FRC #0192
Datalore is an unknown quantity at this point
Re: jars: creating and adding
From command line,
ant jar-app
to make the jar file
To add the proper syntax highlighting things, you have to add it to the netbeans classpath file, as you have done.
To deploy the library jar with the rest of the code, run
ant deploy -Dutility.jars=myLibrary.jar
AndyMark Wheels- adding sprockets, bolts, and such Bryan Herbst SolidWorks 14 31-05-2008 22:01
Adding hinges and a door lock to the crate Mikhail_Pham Technical Discussion 1 18-02-2008 17:47
Creating and selling parts. Billfred General Forum 30 21-07-2004 00:18
Adding Sound Effects and Music to an Animation Hailfire 3D Animation and Competition 19 26-01-2004 23:10
Adding stickers and Cosmetic detail at competition archiver 2001 3 24-06-2002 01:29
